MKR 1500 NB crashing when not connected to the USB Port of my PC
I am having an issue where - When my MKR 1500 NB is connected to my PC the code runs perfectly, when disconnected from my PC the code runs for a small while then crashes.
The controller controls lights via DMX using the Arduinodmx library.
I have seen many posts with people that have had similar issues and the advice is often to check the power supply.
I don't believe this to be my problem for a few reasons.
But mainly because if I sever the two data lines of the USB and leave the USB connected to the PC the issue remains, so I would think that supplying the MKR with the additional power supply is not helping, but the actual connection to the Serial is stopping the issue from revealing itself.
I don't think the schematic is relevant as the issue is still present even when nothing is connected to the MKR except the USB cable with the two data lines severed.
I have had many many iterations of this code trying to solve what I originally thought was a memory overflow issue, but here is my current code below...
Can I give tips to whoever solves this? I am at my wits end!!
#include "arduino_secrets.h"
  Sketch generated by the Arduino IoT Cloud Thing "Untitled"
  https://create.arduino.cc/cloud/things/8ea158c5-d0be-4d41-9050-66ef8f808e54
  Arduino IoT Cloud Variables description
  The following variables are automatically generated and updated when changes are made to the Thing
  float current;
  int colour;
  CloudSchedule hbSched;
  CloudSchedule onTime;
  bool heartbeat;
  bool power;
  Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
  which are called when their values are changed from the Dashboard.
  These functions are generated with the Thing and added at the end of this sketch.
// ArduinoRS485 - Version: Latest
#include <ArduinoRS485.h>
// ArduinoDMX - Version: Latest
#include <ArduinoDMX.h>
#include "thingProperties.h"
#include <MemoryFree.h>;
#include <pgmStrToRAM.h>;  // not needed for new way. but good to have for reference.
#define ch1 1
#define ch2 2
#define ch3 3
#define ch4 4
const int hbPin = 8;
const int statusB = 3;
const int currentPin = A0;
const int testPin = 6;
const int universeSize = 4;
unsigned long lastToggleTime = 0;
bool statusBState = false;
int counter = 0;
int resetCounter = 0;
unsigned long totalCurrent = 0;
  //Serial.begin(9600);
  //delay(1500);
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  pinMode(hbPin, OUTPUT);
  pinMode(statusB, OUTPUT);
  pinMode(currentPin, INPUT);
  DMX.begin(universeSize);
  ArduinoCloud.update();
  //Serial.println(freeMemory());
  dmxLoop();
  checkHeartbeat();
  toggleStatusB();
  currentLoop();
  //Serial.println(colour);
  //Serial.println(heartbeat);
  //Serial.println(current);
  //Serial.println(counter);
  //Serial.println(totalCurrent);
void dmxLoop() {
  DMX.beginTransmission();
  if (onTime.isActive()) {
    power = true;
    switch (colour) {
      case 1:  //Static Red
        DMX.write(ch1, 255);
        DMX.write(ch2, 255);
        DMX.write(ch3, 255);
        DMX.write(ch4, 108);
      case 2:  //Static Green
        DMX.write(ch4, 0);
      case 3:  //Static Yellow
        DMX.write(ch3, 108);
        DMX.write(ch4, 255);
      case 4:  //Static Blue
      case 5:  //Static Magenta
        DMX.write(ch4, 0);
      case 6:  //Static Cyan
        DMX.write(ch3, 0);
      case 7:  //Static White
        DMX.write(ch3, 0);
      case 8:  //Static Multicoloured
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 9:  //2 second fade up and down in RED
        DMX.write(ch1, 0);
        DMX.write(ch3, 0);
      case 10:  //2 second fade up and down in GREEN
        DMX.write(ch1, 0);
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 11:  //2 second fade up and down in YELLOW
        DMX.write(ch2, 108);
      case 12:  //2 second fade up and down in BLUE
      case 13:  //2 second fade up and down in MAGENTA
        DMX.write(ch4, 0);
      case 14:  //2 second fade up and down in CYAN
      case 15:  //2 second fade up and down in WHITE
      case 16:  //2 second fade up and down in MULTICOLOUR
        DMX.write(ch4, 0);
      case 17:  //Fast white twinkle in RED
        DMX.write(ch1, 108);
      case 18:  //Fast white twinkle in GREEN
        DMX.write(ch4, 0);
      case 19:  //Fast white twinkle in YELLOW
      case 20:  //Fast white twinkle in BLUE
      case 21:  //Fast white twinkle in MAGENTA
        DMX.write(ch4, 0);
      case 22:  //Fast white twinkle in CYAN
        DMX.write(ch3, 0);
      case 23:  //Fast white twinkle in WHITE
        DMX.write(ch3, 0);
      case 24:  //Fast white twinkle in MULTICOLOUR
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 25:  //All off with fast twinkle in RED
        DMX.write(ch1, 0);
      case 26:  //All off with fast twinkle in GREEN
        DMX.write(ch1, 0);
        DMX.write(ch4, 0);
      case 27:  //All off with fast twinkle in YELLOW
        DMX.write(ch1, 0);
        DMX.write(ch3, 0);
      case 28:  //All off with fast twinkle in BLUE
        DMX.write(ch1, 0);
        DMX.write(ch3, 0);
      case 29:  //All off with fast twinkle in MAGENTA
        DMX.write(ch1, 0);
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 30:  //All off with fast twinkle in CYAN
        DMX.write(ch2, 0);
      case 31:  //All off with fast twinkle in WHITE
        DMX.write(ch2, 0);
      case 32:  //All off with fast twinkle in MULTICOLOUR
        DMX.write(ch2, 0);
        DMX.write(ch4, 0);
      case 33:  //Slow white twinkle on RED
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
      case 34:  //Slow white twinkle on GREEN
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 35:  //Slow white twinkle on YELLOW
        DMX.write(ch2, 0);
      case 36:  //Slow white twinkle on BLUE
        DMX.write(ch2, 0);
      case 37:  //Slow white twinkle on MAGENTA
        DMX.write(ch2, 0);
        DMX.write(ch4, 0);
      case 38:  //Slow white twinkle on CYAN
        DMX.write(ch2, 0);
      case 39:  //Slow white twinkle on WHITE
        DMX.write(ch2, 0);
      case 40:  //Slow white twinkle on MULTICOLOUR
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
        DMX.write(ch4, 0);
      case 41:  //Twinkling slowly to off in RED
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
      case 42:  //Twinkling slowly to off in GREEN
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
      case 43:  //Twinkling slowly to off in YELLOW
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
      case 44:  //Twinkling slowly to off in BLUE
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
      case 45:  //Twinkling slowly to off in MAGENTA
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
      case 46:  //Twinkling slowly to off in CYAN
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
        DMX.write(ch4, 0);
      case 47:  //Twinkling slowly to off in WHITE
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
      case 48:  //Twinkling slowly to off in MULTICOLOUR
        DMX.write(ch1, 0);
        DMX.write(ch2, 0);
        DMX.write(ch3, 0);
      case 49:  //Off with slow twinkle in RED
      case 50:  //Off with slow twinkle in GREEN
        DMX.write(ch4, 0);
      case 51:  //Off with slow twinkle in YELLOW
        DMX.write(ch1, 0);
      case 52:  //Off with slow twinkle in BLUE
        DMX.write(ch1, 0);
      case 53:  //Off with slow twinkle in MAGENTA
        DMX.write(ch1, 0);
        DMX.write(ch4, 0);
      case 54:  //Off with slow twinkle in CYAN
        DMX.write(ch3, 0);
      case 55:  //Off with slow twinkle in WHITE
        DMX.write(ch3, 0);
      case 56:  //Off with slow twinkle in MULTICOLOUR
        DMX.write(ch3, 0);
        DMX.write(ch4, 0);
    }  // Close switch
  }  // if (onTime.isActive())
  else {  //Set DMX output to OFF
    power = false;
  }  // Close else
  DMX.endTransmission();
void checkHeartbeat() {
  if (hbSched.isActive()) {
    heartbeat = true;
    digitalWrite(hbPin, HIGH);
    heartbeat = false;
    digitalWrite(hbPin, LOW);
void toggleStatusB() {
  if (millis() - lastToggleTime >= 500) {
    lastToggleTime = millis();
    statusBState = !statusBState;
    digitalWrite(statusB, statusBState);
    digitalWrite(testPin, statusBState);
void currentLoop() {
  static unsigned long lastExecutionTime = 0;  // initialize the last execution time variable
  // check if 9ms have passed since the last execution
  if (millis() - lastExecutionTime >= 9) {
    lastExecutionTime = millis();  // update the last execution time variable
    int currentValue = analogRead(A0);
    if (currentValue > 512) {
      totalCurrent += currentValue;
    counter++;
    if (counter >= 1479) {
      current = totalCurrent / 1480;
      counter = 0;
      totalCurrent = 0;
  Since Power is READ_WRITE variable, onPowerChange() is
  executed every time a new value is received from IoT Cloud.
void onPowerChange() {
  // Add your code here to act upon Power change
  Since Colour is READ_WRITE variable, onColourChange() is
void onColourChange() {
  // Add your code here to act upon Colour change
  Since Current is READ_WRITE variable, onCurrentChange() is
void onCurrentChange() {
  // Add your code here to act upon Current change
  Since HbSched is READ_WRITE variable, onHbSchedChange() is
void onHbSchedChange() {
  // Add your code here to act upon HbSched change
  Since Heartbeat is READ_WRITE variable, onHeartbeatChange() is
void onHeartbeatChange() {
  // Add your code here to act upon Heartbeat change
  Since OnTime is READ_WRITE variable, onOnTimeChange() is
void onOnTimeChange() {
  // Add your code here to act upon OnTime change
Why do you say the code is "crashing"? What are the symptoms of that?
I noticed that all your Serial.print() are commented out. If you run the Arduino connected to pc with serial monitor open, do you see any characters printed?
I have a suggestion that will dramatically reduce the length of your code, if you are interested.
Hi @PaulRB, Thank you so much for your reply.
I have in the code a snippet that toggles the L LED every 500ms, when the board 'crashes' this led stops flashing, after a while and after it has reconnected to the cloud the LED starts flashing again.
Additionally, my LED lights flash randomly when the Arduino is resetting, this also happens when the MKR 'crashes'. It is pretty recognisable.
Yes, there are a number of lines printed by the IoT cloud library, as the Arduino connects, I can see these.. Sim Card OK, Connected to IoT cloud etc. Interestingly, when I comment out serial.begin, I can still see this text, and any other Serial.prints that aren't commented out also.
My goodness yes!!!
Ty Paul,
Best,
M
I wonder if, when not connected to the pc, because the Arduino knows that the serial port is not connected, the serial buffer is becoming full, stalling the code at one of the Serial.print() lines.
But if the IoT cloud library always uses Serial.print(), no sketch would ever work on the MKR NB 1500 unless it was connected to a pc. If that were true it would make the board pointless, it's supposed to run standalone, so it can't be that.
It's that huge switch-case statement that could be completely removed. Whenever you see code, that is almost the same, being repeated multiple times (56 times in your code) that's a sign that you could/should have written it another way.
Symbols or variables with numbers in their names is another clue.
Arrays are your friends in these situations.
const byte channels = 4;
const byte ch[channels] = {1, 2, 3, 4};
const byte colours = 57;
const byte pattern[colours][channels] = {
  {255, 255, 255, 255}, //Set DMX output to OFF
  {255, 255, 255, 108}, //1: Static Red
  {255, 255, 255,   0}, //2: Static Green
  {255, 108,   0, 108}, //55: Off with slow twinkle in WHITE
  {255, 108,   0,   0} //56: Off with slow twinkle in MULTICOLOUR
Then you can replace the entire switch-case statement with this single line:
for (byte c=0; c<channels; c++) DMX.write(ch[c], pattern[colour][c]);
Hi @PaulRB,
Thank you for your time writing this out.
Some follow up questions if I may...
Do arrays not use more memory? I wrote the switch statement out this way with 'never forgo clarity for brevity' in mind (Or however the saying goes?).
#define ch1 1
#define ch2 2
As for these, this makes it easy for me to change the start DMX address as this code, if it were working would be uploaded to different locations where the start address would be different.
Very keen to hear your thoughts, you aren't suggesting that this is causing my issue btw?
Best,
M
More dynamic memory (ram), yes. That can probably be prevented if necessary, but that array will use around 200 bytes, and your arduino has 32K bytes. Your code would be shorter, so less program memory (flash) used.
It's a good principle to always keep in mind. But avoiding repetition in code is also a good principle and your code is repeating the same thing 50+ times over. If you need to change that piece of code, you have to do that change 50+ times over.
Can you give an example? I don't see how my suggestion would make changing the start address more difficult.
Not sure what you mean by "this", but, no, pretty sure my suggestions won't fix your stalling problem, sorry.
Hi @PaulRB
The arduino generated IoT memory uses a huge amount of this 32K, like over 90%, so I am being quite careful about RAM used, I will definitely load your code though and if it doesn't tip the scales, I very much prefer it to my method.
I was really just explaining why I was using variable names with numbers, but your way is far better.
I believe I have fixed my stalling problem thank you for your help. The reason why I was confused (I think) is that when I severed the data lines on my USB cable, my computer was turning off the power, I am guessing this is because of some sort of PD negotiation or similar. I am unsure, but when I connected the Arduino to a power bank it starting working correctly. The issue I was having is that I was powering the Arduino through a SSR, I did this so that the Arduino would be power cycled if it ever lost comms with the cloud. (Long Story). Anyway, I have changed this to a mechanical relay and my rebooting woes seem to have subsided.
Best,
M
