MKR 485 Shield don't get a receive from Piezo Motor Controller via RS485
I'm currently working on the following project:
I want to send and receive data to a Piezo driver via RS485.
For that purpose, I use this hardware:
The MKR 485 Shield is connected like that to the PMD401:
Y to Data+
Z to Data-
GND to GND
And jumper positions
  • FULL set to OFF
  • Z // Y set to ON
And here is my code:
#include <ArduinoRS485.h>
  RS485.begin(115200);
  RS485.receive();
int counter = 0;
byte rx_byte = 0;
  Serial.print("Count No: ");
  Serial.println(counter);
  RS485.beginTransmission();
  RS485.write("X1J20,0,150\r");
  RS485.write("X1E\r");
  Serial.flush();
  while (RS485.available()) {
    // get a byte RS485
    rx_byte = RS485.read();
    // send the byte to the Monitor
    Serial.write(rx_byte);
  RS485.endTransmission();
  Serial.println(" ");
  delay(10000);
  counter ++;
And the output from the terminal:
Count No: 1
X1J20,0,150X1E
Count No: 2
X1J20,0,150X1E
Count No: 3
X1J20,0,150X1E
What I don't understand is the following:
If I send the command
RS485.write("X1J200,0,200\r");
The motor runs. -> so sending works, I think.
But if I send that command (like it is written in the manual page 2, point 7)
I get no feedback at all. (like you see in the terminal)
So what do I have to do, that the Controller gives me feedback from the encoder? I tried a lot of different commands from the manual, but nothing works.... :frowning: It just reads the last sent commands.
You probably should read the response from the driver after the first command before you send the next command. Remember, RS-485 is (in most cases) a half-duplex connection. If you send the second command while the device sends you an answer it will be lost.
