MKR 485 Shield
It says here (near bottom) that it uses pins A4/A5 for enable pins:
But in the PDF schematic it shows pins A5/A6 for enable:
Which one is right?
On the software library side of things, can you use any 2 pins for enable or are there limitations on which can be used?
It’s A5 and A6. The Getting Started page is wrong.
BillC48:
You can use any 2 pins you like, as long as you don’t use the same pins that you’re using for the serial interface with the shield. Most people will use pins 13 and 14 (Serial1) for the serial interface.
