MKR Battery Not Charging
Hello all,
I have been using an MKR wifi 1010 with a 3.7V 1000 mAh LIPO battery successfully for a few months now, but suddenly after 0 wiring or code changes the battery will not charge and shows as 0v when connected to my DMM, and there is 0 v across it even when connected and the mkr is externally powered. This leads me to believe it is a charge controller issue; either it is broken or it senses a fault with the battery.
The CHRG light turns on for a few seconds on boot then turns off; should I be ordering a new MKR, a new battery, or both?
Hi there,
I was discussing issues with battery: MKR Wifi 1010 battery status/control - MKRWIFI1010 - Arduino Forum
Would you mind showing how the battery is connected? I am not sure whether the battery polarities are swapped.
Many thanks,
Juanma
