I have acquired a Schnyder Electric ILA1 stepper motor with an integrated Lexium drive. This motor uses a CANopen communication protocol (not sure what commands yet). I am waiting to hear back from Schnidyer Electric on the specific commands. I bought a MKR zero and an MKR CAN shield to communicate with it. So far I have found no "nube friendly" help on how to build a sketch to run this thing. My end goal is to use it to open a sliding door. I have a working sketch for operation but I am clueless on CANopen protocol and syntax. From what I have read it seems to be a bit of a pain in the A$$ to work with, but that's what I have. Any help, reference material, magic wand, tutorial, or Trebuchet (to launch this at my rivals) would be appreciated.
This is the sketch I am using:
const int TRIGPin = 0;// Push Button to triger the open command
const int OLIMPin = 1;// Open limit switch to stop the open command
const int CLIMPin = 4;// Close limit switch to stop the close command
const int OpenTime = 10000;// Time to stay open before starting the close command
// variables will change:
volatile int TRIGState; // variable for reading the pushbutton status
volatile int OLIMState; // variable for reading the pushbutton status
volatile int CLIMState; // variable for reading the pushbutton status
volatile int StatusCode; // 0 = Closed, 1 = Opening, 2 = Open, 3 = Timing out, 4 = Closing, 5 = Mid-close open
void OpenInterrupt () {
int TRIGState = digitalRead(TRIGPin);
int OLIMState = digitalRead(OLIMPin);
int CLIMState = digitalRead(CLIMPin);
if (StatusCode == 0 && TRIGState == 1 && OLIMState == 0 && CLIMState == 1) { //Open button is pressed and openlimit is off then set status to 1 (Opening)
StatusCode = 1;
if (TRIGState == 1 && OLIMState == 0 && CLIMState == 0) {
StatusCode = 5;
void OpenedInterrupt () {
if (StatusCode == 1 && OLIMState == 1) { //When the open limit is reached and the status is 1, the set status to 2 (opened)
StatusCode = 2;
void ClosingInterrupt () {
if (StatusCode == 4 && CLIMState == 1 && TRIGState == 0) {//When the door has closed then the status is reset to 0 (Closed)
StatusCode = 0;
pinMode(TRIGPin, INPUT);
pinMode(OLIMPin, INPUT);
pinMode(CLIMPin, INPUT);
attachInterrupt (TRIGPin, OpenInterrupt, RISING);
attachInterrupt (OLIMPin, OpenedInterrupt, RISING);
attachInterrupt (CLIMPin, ClosingInterrupt, RISING);
if (StatusCode == 1) {
// Door Open Code
Serial.println("Opening");
if (StatusCode == 2) {
Serial.println("Holding Open");
delay(OpenTime);
StatusCode = 3;
if (StatusCode == 3) {
// Door close Code
Serial.println("Closing");
StatusCode = 4;
if (StatusCode == 5) {
// Door Stop
Serial.println("Stoping");
delay(2000);
StatusCode = 1;
Serial.print("StatusCode, ");
Serial.println(StatusCode);
Serial.print("Open Button, ");
Serial.println(TRIGState);
Serial.print("Open Limit, ");
Serial.println(OLIMState);
Serial.print("Close Limit, ");
Serial.println(CLIMState);
}const int TRIGPin = 0;// Push Button to triger the open command
StatusCode = 1;
StatusCode = 5;
StatusCode = 2;
StatusCode = 0;
// Door Open Code
delay(OpenTime);
StatusCode = 3;
// Door close Code
StatusCode = 4;
// Door Stop
delay(2000);
StatusCode = 1;
//Debugging
