Hi all
Recently dived into the Arduino world and hit a wall trying to run the MKR CAN shield on the MKR GSM 1400 board. There seems to be limited info and examples available for the MKR CAN shield, so I'm turning to you guys for help.
I've started with the Sandeep Mistry CAN library, installed through library manager, and tried to run one of the OBDII examples (EngineRPM).
I've tried the setup both on vehicle and on bench with CANape attached to verify Tx/Rx messaged. My MKR CAN shield does not seem to transmit anything on CAN though.
Checks completed:
- CAN hi/lo from CAN shield to OBD connector continuity
- CAN hi/lo both reading cte 2.5V from shield pin to shield GND
- Modified CS and INT pin assignments in code to resp. 3 and 7, with INT pin attached as interrupt (see code).
- Tried different clock speeds / SPI frequencies
- However unlikely, tried supporting MKR GSM with 3.7V lipo in case current draw exceeded
Any thoughts why MKR CAN shield is apparently not sending any messages?
#include <CAN.h>
#include <MKRGSM.h>
const bool useStandardAddressing = true;
float rpm = 0;
int cs = 3;
int irq = 7;
int freq = 10E6;
int clockFrequency = 16E6;
bool incomingMSG = false;
while (!Serial);
attachInterrupt(digitalPinToInterrupt(7), readCAN, CHANGE);
CAN.setPins(cs,irq);
CAN.setSPIFrequency(freq);
CAN.setClockFrequency(clockFrequency);
Serial.println("CAN OBD-II engine RPM");
// start the CAN bus at 500 kbps
if (!CAN.begin(500E3)) {
Serial.println("Starting CAN failed!");
while (1);
else{
Serial.println("CAN started");
// CAN msg filtering
if (useStandardAddressing) {
CAN.filter(0x7e8);
CAN.filterExtended(0x18daf110);
CAN.beginPacket(0x7df, 8);
CAN.beginExtendedPacket(0x18db33f1, 8);
CAN.write(0x02); // number of additional bytes
CAN.write(0x01); // Mode 1
CAN.write(0x0c); // engine RPM PID
CAN.write(0); //
CAN.write(0); //
CAN.write(0); //
CAN.write(0); //
CAN.write(0); //
CAN.endPacket();
Serial.println("Message sent");
// Method 1: wait for response
// while(CAN.parsePacket() == 0 ||
// CAN.read() < 3 || // correct length
// CAN.read() != 0x41 || // correct mode
// CAN.read() != 0x0c); // correct PID
// Method 2: look for INT
if (incomingMSG) {
Serial.println(CAN.read());
rpm = ((CAN.read() * 256.0) + CAN.read()) / 4.0;
Serial.print("Engine RPM = ");
Serial.println(rpm);
delay(5000);
void readCAN() {
incomingMSG != incomingMSG;
Serial.println("Incoming message");
