Hello,
I have some great problems with the MKR FOX1200 in combination with the serial monitor.
For example: I reduced my problem to the minimum sketch:
pinMode(6,OUTPUT); // LED at pin 6: MKR FOX1200
// pinMode(13,OUTPUT); // LED at pin 13: UNO_R3-Board (Clone)
while(1)
digitalWrite(6,HIGH);
delay(100);
digitalWrite(6,LOW);
delay(100);
IDE 1.8.12:
Sketch on UNO_R3 (Clone):
- Load sketch: LED flashes
- Start ser. monitor: flashes stops shortly, and then flashes continues
- Close ser. monitor: flashes continues
- Close IDE: flashes continues
This is ok and normaly. But and now:
Sketch on MKR FOX 1200:
Start ser. monitor: flashes continues withot a short break
Close ser. monitor: flashes stops the whole program stops. One or two times reset: no effect !!
Load the sketch again: LED flashes.
Close the IDE: flashes continues.
After closing the ser. monitor the yellow LED on the board flashes slowly and weak. So I think the baord is in the boot modus and the user program does not run.
I think the the closing of the ser. monitor puts the board into the boot modus.
I think this is not normal, because the user program does not run furthermore.
Furthermore the ser. monitor switches every time the usb-port. So every time when I want to download a sketrch, I have first to select the right usb-port again.
Can anybody help me with this problem ?
Thank you very much.
Best regards
Herby
