MKR GSM 1400 program causes USB error
When I add an interrupt to my code, the MKR is no longer recognized by my development IDE.
I can't even seem to reinstall the bootloader.
Any ideas? - I have 4 MKR now that I can't use.
Here is a code snippet
// the setup function runs once when you press reset or power the board
#define RED_LED 9
#define GREEN_LED 8
#define PB 6
volatile bool m_PB_Down = false;
volatile bool m_B_Down = false;
// initialize digital pin LED_BUILTIN as an output.
pinMode(RED_LED, OUTPUT);
pinMode(GREEN_LED, OUTPUT);
pinMode(PB,INPUT);
// TURN ON GREEN LED
//Green_Led_Status(HIGH);
attachInterrupt(digitalPinToInterrupt(PB),PB_ISR, LOW);
if (m_PB_Down) {
Red_Led_Status(HIGH);
Green_Led_Status(LOW);
m_PB_Down=false;
void PB_ISR(){
m_PB_Down = true;
(deleted)
spycatcher2k:
Here is a snippet of my answer :
Hi - all you need to do is . . . . .
:smiley:
I love how newbies who don't know anything presume to spoon feed us what they believe is "relevant" to their problem.
Double click the RESET button to force the board into bootload mode then upload the BLINK sketch. If this works, the board and bootloader are OK.
