confusing the heck out of myself now especially with the remotenumber part for making the call, would be really nice if I could visualise this graphically, may be able to understand what being saved where where it should go...
also I realise I have not added the "+" yet but was saving that for a Friday headache challenge
Receive number by SMS and make Voice Calls to that number a specified number of times
Modified Aug 2019
by Dano with help from J-M-L and the rest of the Arduino Forum
#include <MKRGSM.h> //this is the MKR GSM library
const char PINNUMBER[] = "0000"; //SIM Pin although the MKR GSM voice call example has a seperate SECRET tab for entering this
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms; //required to receive an SMS
GSMVoiceCall vcs; //required to make a voice call
String remoteNumber = ""; // the number you will call, this is somewhat confusing as this is the calling number in the "make voice call" example in the library
char charbuffer[20];
// Array to hold the number a SMS is retreived from
char senderNumber[20];//this is not required but useful for fault finding or identifying unexpected SMS from other sources
// Array to hold the text of the SMS
const byte maxSMSLength = 50;
char smsMessageBody[maxSMSLength + 1];
// initialize serial communications and wait for port to open:
Serial.begin(115200);//check this is the same in the monitor
while (!Serial) ;
// Start GSM connectionx
bool connected = false;
while (!connected) {
if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
connected = true;
Serial.write('.');
Serial.println("GSM initialized");
Serial.println("Waiting for messages");
int c;
// If there are any SMSs available()
if (sms.available()) {
Serial.println("Message received from:");
// Get remote number
sms.remoteNumber(senderNumber, 20);
Serial.println(senderNumber);
// Read message bytes and print them
int i = 0;
while (((c = sms.read()) != -1) && (i < maxSMSLength)) {
smsMessageBody[i++] = c;
smsMessageBody[i] = '\0'; // terminate the cString correctly
Serial.print(F("Received:"));
Serial.println(smsMessageBody);//all working fine until here
// Delete message from modem memory
sms.flush();
// this is now where you need to parse the SMS body.
// assume the format is "+447771871234, 20"
// here this is a crude parser, with no test for error
// parse using strtok: http://www.cplusplus.com/reference/cstring/strtok/
strtok (smsMessageBody, "+"); // replace the + by a NULL CHAR
const char * phoneNumberToCallPtr = strtok (NULL, ","); // replace the ',' by a NULL char, pointer after the ','
const char * totalNumberOfCallsPtr = strtok (NULL, ""); // we just want the next pointer
// transform the string into a number http://www.cplusplus.com/reference/cstdlib/atoi/
const int totalNumberOfCalls = atoi(totalNumberOfCallsPtr);
Serial.print(F("Calling [+"));//does not appear to work from this point
Serial.print(phoneNumberToCallPtr); // carefull we removed the +
Serial.print(F("] for "));
Serial.print(totalNumberOfCalls);
Serial.print(F(" times"));
for (int callNb = 0; callNb < totalNumberOfCalls; callNb++) {
Serial.print(F("Call #"));
Serial.print(callNb + 1);
// HERE PUT THE CODE TO PLACE A CALL
// remember to add the + in the dialing
// (see example in https://www.arduino.cc/en/Reference/GSMVCSVoiceCall)
// Call the remote number
remoteNumber.toCharArray(charbuffer, 20);
// Check if the receiving end has picked up the call
if (vcs.voiceCall(charbuffer))
Serial.println("Call Established. Enter line to end");
// Wait for some input from the line
while (Serial.read() != '\n' && (vcs.getvoiceCallStatus() == TALKING));
// And hang up
vcs.hangCall();
so the part of this that is not working I think is the strtok function because it prints "Calling (+) for 0 times" so this leads me to believe that phoneNumberToCallPtr and totalNumberOfCallsPtr are not being saved or have been replaced somehow, the fact that it doesn't call the number indicates it missing also
NB if I use square brackets around the plus sign the forum converts that to a bullet, in the monitor it shows square brackets on the same line
J-M-L the first code needs to be pasted into the receive SMS example right? I appended the setup and removed the loop but this will not compile, gives me a specific error "Error compliing for board Arduino MKR GSM 1400"
No my code should be self sufficient unless I've typos
#include <MKRGSM.h>
const char PINNUMBER[] = "0000"; // << REPLACE WITH YOU PIN
GSM gsmAccess;
GSM_SMS sms;
while (!Serial) ;
connected = true;
Serial.write('.');
int c;
int i = 0;
sms.flush();
// assume the format is "+YYxxxxxxxxxxx, 20"
this should decode the SMS you are sending - but not doing anything smart with it as the loop for making the calls is empty
if you are 100% sure that the SMS you will send will be well formatted with just the number to call, a comma and the number of repetition, you can even simplify the parsing (which then will get the +) with finding where the comma is and that's it.
you can use strchr() to find the pointer to the comma, replace the comma by a '\0' and then add 1 to that pointer and pass that to atoi()
here is a quick example on how to use strchr()
const byte maxSMSLength = 100;
// simulate receiving the SMS
strcpy(smsMessageBody, "+4412345678,20");
char* const phoneNumberToCallPtr = smsMessageBody;
char* const commaPointer = strchr(smsMessageBody, ','); // http://www.cplusplus.com/reference/cstring/strchr/
if (commaPointer != NULL) {
*commaPointer = '\0'; // put a NULL char there so that we have a well formed cString for the phone number
const int totalNumberOfCalls = atoi(commaPointer + 1); // we parse what's after the comma
Serial.print(F("Calling ["));
} else Serial.println(F("No comma, error. SMS format has to be +CCxxxxxxxxxx,nn"));
void loop() {}
I have tried to merge both of those examples into the read SMS and voicecall examples, there is still the issue of either reading/saving the SMS content or writing it so I am not even able to determine of the rest of the code will make the voice call which I do not believe it will because of the "remoteNumber" string
getting very confused now, any assistance would be very much appreciated
receive SMS, extract content and call number specified number of times
// libraries
#include <MKRGSM.h>
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[] = SECRET_PINNUMBER;
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("SMS Messages Receiver");
// connection state
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
connected = true;
Serial.println("Not connected");
Serial.println("GSM initialized.");
int c;
int i = 0;
sms.flush();
// add any incoming characters to the String:
while (Serial.available() > 0) {
char inChar = Serial.read();
// if it's a newline, that means you should make the call:
if (inChar == '\n') {
// make sure the phone number is not too long:
if (remoteNumber.length() < 20) {
// let the user know you're calling:
Serial.print("Calling to : ");
Serial.println(remoteNumber);
if (vcs.voiceCall(charbuffer)) {
// And hang up
vcs.hangCall();
Serial.println("Call Finished");
remoteNumber = "";
Serial.println("Enter phone number to call.");
Serial.println("That's too long for a phone number. I'm forgetting it");
remoteNumber = "";
// add the latest character to the message to send:
if (inChar != '\r') {
remoteNumber += inChar;
I don't understand why J-M-L's example is not working correctly and there appears to be an issue with the persistence of the multiple pointers. When I test his code on a Uno in a non GSM context but using software serial from the monitor it parses and prints correctly.
That said, I have always used strtok with a single pointer and strcpy to secondary char arrays for use in the code. See if this approach preserves the parsed message. If this is successful, I would add code to clear, rather than overwrite, the transfer strings each time there is a new message.
// libraries
#include <MKRGSM.h>
// PIN Number
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
char phoneNumberToCall[16];//size for parsed characters
char numberOfCalls[4];//size for parsed characters
while (!Serial) {
// connection state
// Start GSM shield
connected = true;
int c;
int i = 0;
sms.flush();
char* strtokIndx;
//const char * phoneNumberToCallPtr = strtok (NULL, ","); // replace the ',' by a NULL char, pointer after the ','
strtokIndx = strtok (NULL, ","); // replace the ',' by a NULL char, pointer after the ','
strcpy(phoneNumberToCall, strtokIndx);
//const char * totalNumberOfCallsPtr = strtok (NULL, ""); // we just want the next pointer
strtokIndx = (NULL, ""); // we just want the next pointer
strcpy(numberOfCalls, strtokIndx);
//const int totalNumberOfCalls = atoi(totalNumberOfCallsPtr);
int totalNumberOfCalls = atoi(numberOfCalls);
//Serial.print(phoneNumberToCallPtr); // carefull we removed the +
Serial.print(phoneNumberToCall);
// And hang up
vcs.hangCall();
remoteNumber = "";
remoteNumber = "";
smsMessageBody Is already a persistent global copy of the sms data.
Having multiple pointers into that buffer should not be wiped. I’m sure they are not. That being said I’m on the go and can’t test code (but you seem to indicate it works OK on a UNO)
Dan - can you 100% confirm you are using the code I posted - with no tweaks?
J-M-L:
Hi J-M-L I am using the first code you shared exactly as you posted, the second code I pasted into the make voicecall example as suggested, I believe its correct although I suspect the actually string used for remotenumber may be incorrect, its a bit beyond my skill level to determine if that would work but as far as serial print after the parse it does not show the number as expected
I will have a go at the example above from cattledog and report back
cattledog:
Hi cattledog, I get the following the following error in this case
exit status 1
invalid conversion from 'const char*' to 'char*' [-fpermissive]
Were getting into areas I don't understand. I'm not clear why we are seeing this error, as typically when using strtok with a UNO and received messages you can use char*.
I see this on Stack Exchange
char* is a mutable pointer to a mutable character/string.
const char* is a mutable pointer to an immutable character/string. You cannot change the contents of the location(s) this pointer points to. Also, compilers are required to give error messages when you try to do so. For the same reason, conversion from const char * to char* is deprecated.
The error may be a clue, since I don't understand why the message being parsed is considered an "immutable" string which causes the error.
strtok definitely modifies the message and replaces the index characters with nulls.
I'm confused as to the error, and the MKR1400 environment.
unless I am misunderstanding your guidance I had already tried that but unfortunately it made little difference
// libraries
#include <MKRGSM.h>
#define SECRET_PINNUMBER ""
// PIN Number
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
while (!Serial) {
// connection state
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes (not required if using SECRETS tab)
connected = true;
int c;
int i = 0;
sms.flush();
// changed from char* strtokIndx;
const char* strtokIndx;
const char* totalNumberOfCallsPtr = strtok (NULL, "");
// And hang up
vcs.hangCall();
remoteNumber = "";
remoteNumber = "";
this is what I see in the serial monitor
16:43:07.514 -> SMS Messages Receiver
16:43:17.702 -> GSM initialized.
16:43:17.702 -> Waiting for messages
16:43:30.127 -> Message received from:
16:43:30.127 -> +31620541234
16:43:30.127 -> Received:+447771871234, 5
16:43:30.166 -> Calling [(plus sign)⸮(backwards question mark)] for 0 times
cattledog:
could well be its the MKR GSM 1400, I did read somewhere that its a different build but I do not understand how that it would require alternative programming, that is also way beyond my skill level
I don't believe you did this as I intended. You need to comment out the previously used pointers from JML's code, and make the strcpy right after the strtok call.
exactly the same result when replaced as you stated
// libraries
#include <MKRGSM.h>
// PIN Number
GSM gsmAccess;
GSM_SMS sms;
GSMVoiceCall vcs;
while (!Serial) {
// connection state
// Start GSM shield
connected = true;
int c;
int i = 0;
sms.flush();
this section replaced with suggested code from cattledog above
int totalNumberOfCalls = atoi(numberOfCalls);*/
// And hang up
vcs.hangCall();
remoteNumber = "";
remoteNumber = "";
