Hey all,
I am trying to achieve the lowest possible sleep current with a MKR wifi1010 + mkr IMU shield. The goal is to take a measurement every 10s.
Stand alone MKR wifi1010
By using the code below, with the 'on' led desoldered and battery powered (3.7V) i achieved a sleep current of 1mA.
// Include libraries
#include <WiFi101.h>
#include <ArduinoLowPower.h>
WiFi.end();
LowPower.deepSleep(10000);
MKR wifi1010 + IMU shield
Now when i attach the MKR IMU shield this sleep current increases to 10mA, which i did not expect, since the deepSleep function should disable everything except the RTC peripherals.
DeepSleep Function
"Puts the MCU in deep sleep mode. The deep sleep mode allows power optimization with the slowest wake-up time. All but the RTC peripherals are stopped. The CPU can be wakeup only using RTC or wakeup on interrupt capable pins."
Question
Is this behaviour expected according to the IMU shield datasheet provided below? If so, is there a way to reduce the power consumption of the IMU shield in sleep mode?
Thanks in advance!
