MKR MEM Shield Instruction Guide
Hello all,
I have the Arduino Uno R3, and I am trying to use the on-board Flash memory of the MKR Mem Shield.
So far, I have followed this tutorial: https://www.arduino.cc/en/Guide/MKRMEMShield#pin-usage
And, I use the Paul Stoffregen's SerialFlash library within the code as you can see.
I have the following test code:
//First, please download the SerialFlash library by Paul Stoffregen
#include <SerialFlash.h>
#include <SPI.h>
#include <Keyboard.h>
const int FlashChipSelect = 5; //CS or Chip Select pin
const int f_Length = 256;
const char* fileName = "text.bin";
delay(5000); // 5 seconds
Serial.println(" Flash chip testing program " );
//Checking if there is a flashChip connected
if(!SerialFlash.begin(FlashChipSelect)){
Serial.println("Unable to access SPI Flash Chip");
}else{
Serial.println("Flash Chip detected");
if(Serial.available() > 0){
char inChar = Serial.read();
if(inChar == 'w'){
Serial.println("Initiating Writing to file");
writeTest(fileName, f_Length);
if(inChar == 'r'){
Serial.println("Initiating Reading to file");
readTest(fileName,f_Length);
void writeTest(const char* fileName, int fLength){
//Check if file exists
Serial.println("Checking if file exists.");
if(SerialFlash.exists(fileName)){
Serial.println("FILE EXISTS");
SerialFlash.remove(fileName);
}else{
//File doesn't exists
//Create the file
Serial.println("file doesn't exists");
if(SerialFlash.create(fileName,f_Length)){
Serial.println("Created file, now writing");
SerialFlashFile ff = SerialFlash.open(fileName);
char buf[256] = "Hello World";
ff.write(buf,256);
ff.close();
Serial.println("Done writing to file.");
}else{
Serial.println("Unable to create file");
void readTest(const char* fileName, int fLength){
Serial.println("File exists!");
SerialFlashFile file = SerialFlash.open(fileName);
char buffer[256];
file.read(buffer, 256);
Serial.println(buffer);
file.close();
WHEN I TEST THE CODE, the serial monitor detects Flash when NO PINS are connected.
What am I doing wrong?
I
