MKR Motor Carrier: Firmware and Connection
When using the MKR Motor Carrier with a MKR Zero I'm notified that the connection fails:
Couldn't connect! Is the red LED blinking? You may need to update the firmware with FWUpdater sketch
The red LED is not blinking but since I couldn't find any more information on what to do I tried flashing the firmare:
10:46:20.320 -> Erase flash
10:46:20.815 -> Starting flash
10:46:21.657 -> 1
10:46:21.657 -> EF
However, it goes on and and on just outputting
10:46:21.657 -> 1
10:46:21.657 -> EF
for many minutes. What can I do?
I adapted the code of the firmware flasher to simply print the current version of the board:
#include "Wire.h"
#include "ArduinoMotorCarrier.h"
  Wire.begin();
  Wire.setClock(1000000);
  while (!Serial);
  pinMode(6, OUTPUT);
  digitalWrite(6, HIGH);
  int prev_address = -1;
  Wire.beginTransmission(0x66);
  Wire.write((uint8_t)GET_VERSION);
  Wire.write((uint8_t)0);
  Wire.endTransmission();
  Wire.requestFrom(0x66, 5);
  Wire.read();
  String version = "";
  while (Wire.available()) {
    Serial.print((char)Wire.read());
    //version += (char)Wire.read();
However, communication doesn't seem to happen either:
10:00:08.671 ->
I reseated controller and carrier but to no avail. Can I suppose that the carrier board is broken? There are no error indicators whatsoever on any of the boards...
