MKR NB 1500 and ARDUCAM + SD Card
I'm having trouble running a camera with an SD card on the MKR NB 1500. My current conclusion is it has something to do with the camera holding onto the SPI controller.
I've tested camera and SD card separately. If i run one of them they work fine.
All I'm trying to do is take a photo, store it on the SD Card.
Hardware:
Arduino MKR NB 1500
Arducam Mini Module Camera 5MP Plus OV5642
Micro SD Card Module from DFRobot DFR0229
Code:
// ArduCAM Mini demo (C)2017 Lee
// Web: http://www.ArduCAM.com
// This program is a demo of how to use the enhanced functions
// This demo was made for ArduCAM_Mini_5MP_Plus.
// It can  continue shooting and store it into the SD card  in JPEG format
// The demo sketch will do the following tasks
// 1. Set the camera to JPEG output mode.
// 2. Capture a JPEG photo and buffer the image to FIFO
// 3.Write the picture data to the SD card
// 5.close the file
//You can change the FRAMES_NUM count to change the number of the picture.
//IF the FRAMES_NUM is 0X00, take one photos
//IF the FRAMES_NUM is 0X01, take two photos
//IF the FRAMES_NUM is 0X02, take three photos
//IF the FRAMES_NUM is 0X03, take four photos
//IF the FRAMES_NUM is 0X04, take five photos
//IF the FRAMES_NUM is 0X05, take six photos
//IF the FRAMES_NUM is 0X06, take seven photos
//IF the FRAMES_NUM is 0XFF, continue shooting until the FIFO is full
//You can see the picture in the SD card.
// This program requires the ArduCAM V4.0.0 (or later) library and ArduCAM_Mini_5MP_Plus
// and use Arduino IDE 1.6.8 compiler or above
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined (OV5640_MINI_5MP_PLUS)||defined (OV5642_MINI_5MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define   FRAMES_NUM    0x01
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
#define SD_CS 4
//const int SD_CS = 6;
bool is_header = false;
int total_time = 0;
#if defined (OV5640_MINI_5MP_PLUS)
  ArduCAM myCAM(OV5640, CS);
#else
  ArduCAM myCAM(OV5642, CS);
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
uint8_t vid, pid;
uint8_t temp;
Wire.begin();
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
pinMode(SD_CS, OUTPUT);
digitalWrite(CS, HIGH);
//digitalWrite(SD_CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
  //Check if the ArduCAM SPI bus is OK
  myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
  temp = myCAM.read_reg(ARDUCHIP_TEST1);
  if(temp != 0x55)
    Serial.println(F("SPI interface Error!"));
    delay(1000);continue;
  }else{
    Serial.println(F("SPI interface OK."));break;
while(1){
  //Check if the camera module type is OV5642
  myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
  myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
  if ((vid != 0x56) || (pid != 0x42)){
    Serial.println(F("Can't find OV5642 module!"));
  }else{
    Serial.println(F("OV5642 detected."));break;
//Initialize SD Card
while(!SD.begin(SD_CS))
  Serial.println(F("SD Card Error!"));delay(1000);
Serial.println(F("SD Card detected."));
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
myCAM.flush_fifo();
  myCAM.OV5640_set_JPEG_size(OV5640_320x240);delay(1000);
#else
  myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
#endif
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
total_time = millis();
while ( !myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
total_time = millis() - total_time;
Serial.print(F("capture total_time used (in miliseconds):"));
Serial.println(total_time, DEC);
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
//Clear the capture done flag
delay(5000);
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
static int i = 0;
static int k = 0;
char str[8];
File outFile;
byte buf[256];
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //8M
  Serial.println("Over size.");
  return 0;
if (length == 0 ) //0 kb
  Serial.println(F("Size is 0."));
  return 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
i = 0;
while ( length-- )
  temp_last = temp;
  temp =  SPI.transfer(0x00);
  //Read JPEG data from FIFO
  if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
    buf[i++] = temp;  //save the last  0XD9
    //Write the remain bytes in the buffer
    myCAM.CS_HIGH();
    outFile.write(buf, i);
    //Close the file
    outFile.close();
    Serial.println(F("OK"));
    is_header = false;
    myCAM.CS_LOW();
    i = 0;
  if (is_header == true)
    //Write image data to buffer if not full
    if (i < 256)
     buf[i++] = temp;
      //Write 256 bytes image data to file
      myCAM.CS_HIGH();
      outFile.write(buf, 256);
      i = 0;
      buf[i++] = temp;
      myCAM.CS_LOW();
  else if ((temp == 0xD8) & (temp_last == 0xFF))
    is_header = true;
    myCAM.CS_HIGH();
    //Create a avi file
    k = k + 1;
    itoa(k, str, 10);
    strcat(str, ".jpg");
    //Open the new file
    outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
    if (! outFile)
      Serial.println(F("File open failed"));
      while (1);
    myCAM.CS_LOW();
    buf[i++] = temp_last;
    buf[i++] = temp;
  myCAM.CS_HIGH();
  return 1;
Any one have ideas? I assume its to do with SPI but let me know if you think otherwise.
Did you ever get this worked out? I am having similar issues.
