MKR NB 1500 board does not get recognized by my computer anymore
Did I brick my MKR NB 1500 board?
  • When I connect the board to my Windows 10 computer, it does not get a COM port number as before. I don't see the board in Device Manager under Ports(COM & LPT) as before, and Windows does not make the typical sound when connecting a new device to it.
  • When I connect the board to my computer via USB:
    -- The ON LED turns on and remains on
    -- The CHRG LED blinks fast.
    -- The reset button does not do anything anymore.
  • I have tried using another USB cable and another USB port but still does not work.
  • I have an Arduino Pro Edge Control board and it works fine using the same USB cables and USB ports, so I know the USB cables and the USB ports are working fine.
  • I tried following the instructions from here: MKR1500 No Longer Recognized, but pressing the reset button twice quickly does not do anything to the board either.
  • I also tried rebooting my computer. I tried using Arduino IDE 1.8 and 2.0. Tried on another computer and nothing.
  • I have its antenna connected and the SIM card in.
  • I opened a ticket with Arduino Support, but they only work on the weekdays, and they usually take days to respond.
so, did I brick my board?
UPDATE: I found an instruction to rebuild the bootloader of my board using another MKR board. I will try this. Updated Guide to easely rebuild the bootloader for MKR Boards with a second MKR (WITHOUT SD Card)
If you opened a ticket with Arduino Support, you will get a reply today or tomorrow. The support team will help you get the issue fixed.
