MKR NB 1500 Freeze if I insert a different sim card.
I have an Arduino MKR1500 NB board. Firstly I used with a Vodafone NB-IOT sim card, with this working well without issues.
But If I insert a different NB-IOT sim cards, it freeze after 5-10 sec and doesn't response answer to at commands. I have a telekom and hologram sim card.
I have a SIMCOM 7020 modem and in this working perfectly all sim so the cards are ok!
Does anyone have any idea what could be wrong?
I am using this very simple code and I using the serial monitor for the at commands.
// baud rate used for both Serial ports
unsigned long baud = 115200;
  // NEVER EVER use RESET_N
  pinMode(SARA_RESETN, OUTPUT);
  digitalWrite(SARA_RESETN, LOW);
  // Send Poweron pulse
  pinMode(SARA_PWR_ON, OUTPUT);
  digitalWrite(SARA_PWR_ON, HIGH);
  Serial.begin(baud);
  SerialSARA.begin(baud);
  if (Serial.available()) {
    SerialSARA.write(Serial.read());
  if (SerialSARA.available()) {
    Serial.write(SerialSARA.read());
Thanks for posting that comments bakonyip95. Sorry, I don't have any solution for you. I've had to include a watchdog in my setup to re-try if I don't get a connection (and it locks up). Not a great solution.
I've had all sorts of problems with NB 1500 boards. So was thinking about converting to use something with a SIM 7020E. Which Arduino are you using with your 7020 and which library?
BTW I use Vodafone and I'm connecting through to Azure IOT hub. Moderately successful with the NB 1500 but often has trouble re-connecting.
