Does anyone know of a breakout board with screw terminals that will fit the MKR1010?
If not, does anyone know the dimensions between the pins and connectors?
Looking for something similar to this: http://a.co/d/fVff1mf
There doesnt appear to be one at the moment but you could always buy the NANO version and cut down the centre to use then as wing type shields.
They are so cheap it would be worth the low cost.
The NANO has one extra pin so you would have a spare terminal on each side with an MKR installed.
Thanks ballscrewbob! I ended up going with this kit, which is perfect for industrial use:
Cost: $45 (includes tax & shipping)
Features:
FYI - The distance between pins on the MKR is 0.1" and between connectors is 0.8".
The Nano is 0.7" between connectors.
WOW I didnt know that existed.
Thanks for coming back.
Yes I know the NANO is narrower which is why I suggested it but cut down the middle.
I have a couple of NANO shields here.
And at $1.50 inc shipping EA it was worth every penny.
There are no traces across the middle so it would have given you screw terminal on every pin.
But DIN rail beats that hands down.
