MKR SD Proto Shield with MKR CAN Shield
Hi all,
I am trying to build a CAN data logger. I have the MKR WAN 1300, MKR Proto shield with the SD port, and the CAN shield. I have found that when I have the CAN shield plugged in the SD card fails to initialize (Using the simple SD library CardInfo script and others). Same setup but if I unplug the CAN shield the card initializes. They both use SPI, but I believe the SD is tied to CS on pin 4 and the CAN shield is tied to pin 3. I have tried both with and without initializing the CAN bus. I am not an expert on SPI but believe it should work with multiple slave with different CS pins.
Am I missing anything?
Arduino IDE v1.8.9
SD library v1.2.3
For the board I used both the default SAMD MKR WAN and the pull request #400... and it didn't work for either.
Any help is appreciated.
Thanks,
I'm looking at the schematic for the MKR Proto SD Shield and it seems there are two versions of the MKR Proto SD Shield. The older version has only the SD card holder. This is the version in the photos on the product page and for which the documentation is written. The newer version has a W28Q16 flash memory chip in addition to the SD card holder (similar to the MKR Mem Shield) and that the schematic and board files provided on the product page are for that version.
You're correct that pin 4 is used as CS on both versions of the shield for the SD card. However, on the new version of the shield pin 3 is used for CS for the flash memory chip.
So please look at your shield to check whether it has an IC on it next to the SD card holder. I attached a screenshot of the board file for the new version of the shield. U1 is the flash IC:
Please let me know what you find.
