MKR THERM SHEILD
Does anyone have a data sheet on the MKR THERM SHIELD Board itself and not the chip it uses?
I am trying to understand how communicate with the MKR THERM SHIELD and UNO board or the computer.
I can not find any seem to be a tutorial or information on how to incorporate this device.
Google "MKR THERM SHIELD".
joshuakujawinski:
The most important thing to understand is that this shield was designed to be used with the MKR boards, which use 3.3 V logic. If you check the "Recommended Operating Conditions" table in the datasheet for the MAX31855K, you'll see that maximum recommended Vcc is 3.6 V and maximum recommended input logic HIGH level is Vcc + 0.3 V. This means that if you connect the MKR Therm Shield directly to your Uno's 5 V logic level, you will damage the MAX31855K. You need to use a level shifter to reduce the 5 V to 3.3 V. You could do this via a resistor voltage divider or one of the level shifter modules that are available from any place you would buy electronics parts.
After that, I recommend studying the Getting Started page for this shield:
https://www.arduino.cc/en/Guide.MKRTHERMShield
and the documentation for the Arduino_MKRTHERM library:
After that, if you have specific questions, I'm sure someone here can answer them.
