Is it possible to have the layout file of the board like by other arduino boards?
This will be useful to populate the connector for the Altera USB Blaster.
Thanks a lot!
pert
January 15, 2019, 10:45pm
2
We do have an open issue in the bug tracker for this:
opened 09:48AM - 25 Jul 18 UTC
Component: Documentation
Type: Bug
"pert" has explained very well here (http://forum.arduino.cc/index.php?topic=559… 429.msg3818022#msg3818022) but as a reminder I post it here.
Following product pages don't offer source files (some haven't been released and that could be understandable yet but some have already been):
- ~~https://store.arduino.cc/usa/mkr-proto-shield~~
- ~~https://store.arduino.cc/mkr-sd-proto-shield~~
- ~~https://store.arduino.cc/arduino-mkr-can-shield~~
- ~~https://store.arduino.cc/arduino-mkr-485-shield~~
- ~~https://store.arduino.cc/arduino-mkr-mem-shield~~
- ~~https://store.arduino.cc/arduino-mkr-connector-carrier~~
- ~~https://store.arduino.cc/arduino-yun-rev-2~~
- ~~https://store.arduino.cc/arduino-uno-wiFi-rev2~~
- ~~https://store.arduino.cc/arduino-mkr-nb-1500~~
- ~~https://store.arduino.cc/arduino-mkr-eth-shield~~
- ~~...and the MKR Motor Carrier which is only sold within the Engineering Kit (why!!??)~~
- ~~https://store.arduino.cc/usa/arduino-fio~~
- ~~https://store.arduino.cc/usa/shield-xbee~~
- https://store.arduino.cc/usa/shield-proto-pcb-rev3
- https://store.arduino.cc/usa/arduino-materia-101-assembled
- https://store.arduino.cc/arduino-pro-gateway
- ~~https://store.arduino.cc/nano-33-ble-sense~~
- ~~https://store.arduino.cc/nano-33-ble~~
- ~~https://store.arduino.cc/nano-33-iot~~
- ~~https://store.arduino.cc/nano-every~~
- ~~https://store.arduino.cc/nano-33-ble-sense-with-headers~~
- ~~https://store.arduino.cc/nano-33-ble-with-headers~~
- ~~https://store.arduino.cc/nano-33-iot-with-headers~~
- ~~https://store.arduino.cc/nano-every-with-headers~~
On the other hand, following product pages only offer schematics:
- ~~https://store.arduino.cc/arduino-mkr-wifi-1010~~
- https://store.arduino.cc/arduino-vidor-4000
There was also a report that the Arduino Industrial 101 .DSN files are only schematics, not board design files: https://forum.arduino.cc/index.php?topic=483772.msg3302961#msg3302961 (this board isn't marked as retired like Tian or others...)
Hopefully it will be published soon.
Limba
January 15, 2019, 11:05pm
3
I think you need adapter cables. J11 (10 pin) connector is 0.05" pitch in pcb and Intel/Altera uses 0.1" pitch connector.
Also signal placement didn't seems to match. Not sure did they do that you can just cut cable and solder it to pcb.
J7 (6 pin) is for SAMD21 debug connector. Haven't checked if that pinout is OK.
I currently use USB BLaster emulator for SAMD21 and I tested it with signaltap with continuous capture.
