What is the difference between the MKR WAN 1300 and the 1310? (I can't find anything on the Arduino Docs website.)
in0
October 16, 2021, 11:39pm
2
There is some information on the MKR WAN 1310 product page:
Arduino MKR WAN 1310 allows you to build your next smart project. Ever wanted an automated house? Or a smart garden? Well, now it’s easy with the Arduino IoT Cloud compatible boards. It means: you can connect devices, visualize data, control and...
Better and More Efficient
The MKR WAN 1310, brings in a series of improvements when compared to its predecessor, the MKR WAN 1300 . While still based on the Microchip® SAMD21 low power processor, the Murata CMWX1ZZABZ LoRa® module, and the MKR family’s characteristic crypto chip (the ECC508), the MKR WAN 1310 includes a new battery charger, a 2MByte SPI Flash, and improved control of the board’s power consumption.
Improved Battery Power
The latest modifications have considerably improved the battery life on the MKR WAN 1310. When properly configured, the power consumption is now as low as 104uA! It is also possible to use the USB port to supply power (5V) to the board; run the board with or without batteries - the choice is yours.
On-board Storage
Data logging and other OTA (Over The Air) functions are now possible since the inclusion of the on board 2MByte Flash. This new exciting feature will let you transfer configuration files from the infrastructure onto the board, create your own scripting commands, or simply store data locally to send it whenever the connectivity is best. Whilst the MKR WAN 1310’s crypto chip adds further security by storing credentials & certificates in the embedded secure element.
So the MKR WAN 1310 is essentially an updated replacement of the 1300 and you should consider the 1300 to be an outdated product.
I believe the fundamental reason for the replacement is that the hardware design of the 1300 resulted in an unnecessarily high power consumption:
opened 07:29PM - 14 Sep 18 UTC
type: imperfection
Hello, I've been working with the MKRWAN1300 and evaluating the sleep performan… ce. I believe I have successfully achieved sleep. However the sleep current is 1.16mA. Is it possible to achieve a sleep current with the MKRWAN1300 of less than 1.16mA?
I have found community reports for other SAMD21 products that achieve a lower sleep current. However, I have not found a report that confirms a sleep current less than 1.16mA for the MKRWAN1300 is achievable.
My hardware configuration is 3.3V power is applied to the Vbatt input. USB is disconnected. A0 (DAC output) is connected to A1 (ADC input).
At the moment I suspect a bug in the MKRWAN firmware preventing the Murata device from sleeping properly but I haven't found anything yet.
Wiring.c in the Arduino library was updated to remove initialization of the IO as floating inputs. I have attached my sketch below for reference.
#include <Arduino.h>
#include <ArduinoLog.h>
#include <ArduinoLowPower.h>
#include <MKRWAN.h>
#include <ZeroRegs.h>
#include <RTCZero.h>
#include "arduino_secrets.h"
#define SLEEP_PERIOD ( (uint32_t) 5000 )
// ADC configuration
#define extSensorPin PIN_A1
#define extSensorEnablePin 1
LoRaModem modem;
static uint32_t msgCount = 0;
bool regsShown = false;
// RTCZero rtc;
// Uncomment if using the Murata chip as a module
// LoRaModem modem(Serial1);
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
String appEui = SECRET_APP_EUI;
String appKey = SECRET_APP_KEY;
void blink( int numBlink = 1, unsigned int speed = 200 ) {
int i;
while ( numBlink-- ) {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(speed); // wait
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
void printTimeStamp(Print* _logOutput) {
char c[12];
int m = sprintf(c, "%10lu ", millis());
_logOutput->print(c);
void printNewline(Print* _logOutput) {
_logOutput->print('\n');
void reboot() {
NVIC_SystemReset();
while(1) ;
void pinStr( uint32_t ulPin, unsigned strength) // works like pinMode(), but to set drive strength
// Handle the case the pin isn't usable as PIO
if ( g_APinDescription[ulPin].ulPinType == PIO_NOT_A_PIN )
return ;
if(strength) strength = 1; // set drive strength to either 0 or 1 copied
PORT->Group[g_APinDescription[ulPin].ulPort].PINCFG[g_APinDescription[ulPin].ulPin].bit.DRVSTR = strength ;
void InitIO() {
// Note: wiring.c initializes all GPIO as inputs with no pull ups ... it has been modified to eliminate this
// Configure digital pins used by the application
pinMode(LED_BUILTIN, OUTPUT);
pinMode(extSensorPin, OUTPUT);
pinStr(extSensorPin, 1);
digitalWrite(extSensorEnablePin, LOW);
// Configure the ADC
analogReadResolution(12);
analogWriteResolution(12);
analogReference(AR_INTERNAL1V65);
void alarmEvent() {
// RTC alarm wake interrupt callback
// do nothing
Log.begin(LOG_LEVEL_VERBOSE, &Serial, true);
InitIO();
int waitForSerial = 5;
while (!Serial && !Serial.available() && waitForSerial ) {
delay(2000);
blink(2);
waitForSerial--;
Log.notice(F("Start" CR));
// initialize the RTC - need to do this or the sleep function is unreliable after reset
// rtc.begin(false);
LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, alarmEvent, CHANGE);
// Log.notice(F("Reset modem ..." CR));
// modem.restart(); // This does not work for some reason
Log.notice(F("Initialize modem ..." CR));
if (!modem.begin(US915_HYBRID)) {
Log.error(F("Failed to start module, rebooting MKRWAN in 1 seconds ..." CR));
reboot();
Log.notice(F("Your module version is: %s" CR), modem.version().c_str());
Log.notice(F("Your device EUI is: %s" CR), modem.deviceEUI().c_str());
int connected = modem.connected();
if ( !connected ) {
int joinFailed = 0;
while ( !connected && joinFailed < 10 ) {
connected = modem.joinOTAA(appEui, appKey);
if (!connected) {
Log.notice(F("LoRaWAN network not joined, retry join in 60 seconds ..." CR));
blink(1);
delay(60000);
joinFailed++;
if ( connected ) {
Log.notice(F("LoRaWAN network joined" CR));
modem.setPort(10);
modem.dataRate(3);
modem.setADR(true);
blink(3);
blink(3);
Log.notice(F("Wake" CR));
// Dump SAMD21 registers
if ( Serial ) {
if (! regsShown ) {
ZeroRegOptions opts = { Serial, false };
printZeroRegs(opts);
regsShown = true;
regsShown = false;
digitalWrite(extSensorEnablePin, HIGH);
analogWrite(PIN_A0, 1024); // apply voltage to DAC to test analog input
delay(10);
int extSensor = analogRead(extSensorPin);
int err;
String msg = "Sleep Test:" + String(msgCount) + ":" + String(extSensor);
modem.beginPacket();
modem.print(msg);
err = modem.endPacket(true);
if (err > 0) {
Log.notice(F("LoRa message sent: %l, vwc = 0x%x" CR), msgCount, extSensor);
msgCount++;
blink(2);
Log.notice(F("LoRa error sending message: %l, vwc = 0x%x" CR), msgCount, extSensor);
blink(1);
blink(3);
LowPower.deepSleep(SLEEP_PERIOD);
All else the same, if you have the choice between the two I would get the 1310. However, if the 1300 is all that is available or available at a significant discount and your application does not require a low power capability then I think it will work fine for you.
system
Closed
September 6, 2022, 1:36am
6
