MKR WAN 1310 lora packet size modification
hello everybody,
I'v just engaged a project that going to employ lora for massage transmission;
But my problem curently is to find every lora packet maxmumly can transfer 11bytes...
Can you advise me how to change code or make configuration... thanks!
A LoRa packet can be from 1 to 255 bytes.
Maybe there is a problem with your code or library.
But you did not post any code, or say which library you are using, so the forum cannot advise.
thanks Srnet!
I m using MKRWAN.h
and just now do the following modifications:
MKRWAN.h modified return size from 64 to 128 as below:
modemGetMaxSize()
if (isArduinoFW()){
return 128;}
sketch modified:
modem.setADR(true);
modem.dataRate(5);
now it can maximumly transfer 71 bytes.
no more i can reached...
or, how to config to maximum 255 bytes when I m using MKRWAN.h, thanks!
Dont know anything about the MKRWAN.h library, but you would think Arduino published documentation for it.
