MKR WIFI 1010 and FTP connection
Hi everyone,
I'm trying to connect my MKR WIFI 1010 to my local FTP server to upload a file through WIFI. I've tried many things but the naswer is always the same : "Not connected error".
I'm a total beginner in FTP/server and things like that.
In term of Arduino, I'm just a little better (I can use it but that's it).
I have no problem to connect to the WiFi, but all the libraries I have tested to connect to the FTP are not working.
The problem (and this is where that won't help you) is that I dunno if it is a problem on my FTP server side (I got it from my internet box), of incompatibilities between libraries and MKR 1010 or about my code (on that part i'm pretty sure it's quite OK since i'm using example).
I've tested various librairies (FTPClient Generic, Simple FTP Server and ESP32 FTP Server which does not work on MKR 1010)
Here is an example of code that is not working (I haven't put the code related to the WiFi connection since it is working well, I managed to send data to my smartphone via Blynk):
#include "Arduino.h"
#include <FTPClient_Generic.h>
#include "arduino_secrets.h"
char ftp_user[]   = SECRET_USER;
char ftp_pass[]   = SECRET_PASS;
char ftp_server[] = "FTP server name";
char dirName[]    = "/Arduino";
  //Initialize serial and wait for port to open:
ftp.OpenConnection();
  ftp.GetFTPAnswer();
  ftp.ChangeWorkDir("/Arduino");
  ftp.InitFile(COMMAND_XFER_TYPE_ASCII);
  ftp.NewFile("helloworld.txt");
  ftp.Write("Hi, I'm a new file");
  ftp.CloseFile();
  String response = "";
  ftp.DownloadString("helloworld.txt", response);
  Serial.println("The file content is: " + response);
  ftp.CloseConnection();
Would you have any hint for me please ? :slight_smile:
Or, would you have an alternative solution since what i'm trying to do is to send sensor data to a storage place other than a SD card (directly available).
Thanks a lot,
And sorry if this is the wrong forum, I hesitated with the MKR 1010 forum.
Iforire
Ok, you have set up an FTP clinet connection, but you do not appear to have any WiFi connection set up?
Presumably your MKR would first need to connected to your WiFi network before you can make a connection to your local FTP server?
https://docs.arduino.cc/tutorials/mkr-wifi-1010/connecting-to-wifi-network
Hi BitSeeker,
I did not put the WiFi connection part in the code as I did not want to pollute the code. It is working and I can connect to my local WiFi.
Here the full code (many things are not useful...)
#include <SPI.h>
#include <WiFiNINA.h>
#include <WiFiUdp.h>
#define USING_VSFTP_SERVER      true
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID;        // your network SSID (name)
char pass[] = SECRET_PASS;    // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0;                                // your network key index number
int status = WL_IDLE_STATUS;                     // the WiFi radio's status
char ftp_server[] = "server name";
FTPClient_Generic ftp (ftp_server, ftp_user, ftp_pass, 60000);
  // check for the WiFi module:
  if (WiFi.status() == WL_NO_MODULE) {
    Serial.println("Communication with WiFi module failed!");
    // don't continue
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
    Serial.println("Please upgrade the firmware");
  // attempt to connect to WiFi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to WEP network, SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, keyIndex, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // once you are connected :
  Serial.print("You're connected to the network");
  printWiFiStatus();
  ftp.GetFTPAnswer();
  ftp.CloseFile();
  unsigned long epoch;
  int numberOfTries = 0, maxTries = 6;
  do {
    epoch = WiFi.getTime();
    numberOfTries++;
void printWiFiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
void printWifiData() {
  // print your board's IP address:
  Serial.println(ip);
  Serial.println(ip);
  // print your MAC address:
  byte mac[6];
  WiFi.macAddress(mac);
  Serial.print("MAC address: ");
  printMacAddress(mac);
void printCurrentNet() {
  // print the MAC address of the router you're attached to:
  byte bssid[6];
  WiFi.BSSID(bssid);
  Serial.print("BSSID: ");
  printMacAddress(bssid);
  Serial.println(rssi);
  // print the encryption type:
  byte encryption = WiFi.encryptionType();
  Serial.print("Encryption Type:");
  Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
  for (int i = 5; i >= 0; i--) {
    if (mac[i] < 16) {
      Serial.print("0");
    Serial.print(mac[i], HEX);
    if (i > 0) {
      Serial.print(":");
Is the FTP server running on a local PC or in the cloud?
if local PC have you set up the firewall to allow the remote connection?
can you run a FTP client and connect to the server ?
Hi Horace.
It's local (on my Internet box) but accessible from anywhere.
I've used FileZilla to acess it, read file and create new file, as I'd like to do with the MKR 1010.
Sorry, i was not very precise in my first post...
Thanks
was this on the same PC as the server or a different machine?
rather then using the server PC name try using its IP address when connecting
it may be worth putting some Serial.println() statements in the code at critical points and then post the serial monitor output
Thanks for clarifying.
Does your FTP server require a username/password, even if it is only 'anonymous' and a blank or some default password?
Have you checked the FTP server logs? They might provide some insight as to whether the server is seeing an attempted connection or has rejected it for some reason.
Indeed, it does, I have put them in an "arduino_secrets.h" file.
Hum, indeed, I saw people doing that when they have problems with their FTP server in different forum posts. I don't know how to do, I'll check that! probably with FileZilla?
On a different machine
I've tried the IP adress and it did not work with the librairies I used.
The code result is that:
You're connected to the networkSSID: ***
IP Address: ***
signal strength (RSSI):-51 dBm
[FTP] ChangeWorkDir: Not connected error
[FTP] InitFile: Not connected error
[FTP] NewFile: Not connected error
[FTP] Write: Not connected error
[FTP] CloseFile: Not connected error
So it goes though the code, but it does not manage to connect tot he FTP server.
When I use IP adress of the FTP server, I do not even get any results from the FTP side '[FTP]'
if you are running the FileZilla FTP server there is the Administration Interface which display FTP client interactions
e.g. just run an FTP client on an ESP32
What FTP server software is it? Is your "Internet server" running Windows? Linux? Mac?
in the code of post 3 you appear to be missing a while() to match the do
Thanks horace and BitSeeker.
I do not know about the FTP server BitSeeker, sorry.
horace, the code is indeed missing a "while" but it's my fault, I removed unecessary parts (about temperature measurements and RTC) and I did not erase it well. The code is working (no errors).
Ill try the FTP FileZilla Server as I do have the client version, thanks!
Arf, I did not manage to connect to the FTP server using FileZilla server (I managed using FileZilla client though!).
I've tried many things since I have an address in the form "ftp://name.name.com" which I can access using the FileZilla Client.
And I have a distant IP address and two ports (one for "control", the other for "data"), both are not working with the FileZilla Client.
Everything is not working with the FileZilla server, giving the errors:
if I run this simple FTP client example on an ESP32 - it lists the root directory and creates a new directory
  FTPClient_DownloadFile.ino
  FTP Client for Generic boards using SD, FS, etc.
  Based on and modified from
  1) esp32_ftpclient Library         https://github.com/ldab/ESP32_FTPClient
  Built by Khoi Hoang https://github.com/khoih-prog/FTPClient_Generic
#include <WiFi.h>
#include <WiFiClient.h>
//#include "defines.h"
// To use `true` with the following PASV mode asnswer from server, such as `VSFTP`
// 227 Entering Passive Mode (192,168,2,112,157,218)
// Using `false` with old style PASV answer, such as `FTP_Server_Teensy41` library
// 227 Entering Passive Mode (4043483328, port 55600)
//#define USING_VSFTP_SERVER      true
#define WIFI_SSID "xxxx"
#define WIFI_PASS "xxxxxxxx"
	// Change according to your FTP server
	char ftp_server[] = "192.168.1.68";
	char ftp_user[]   = "bb";
	char ftp_pass[]   = "horace123";
	char dirName[]    = "/";
	char newDirName[] = "myNewDir22";
// FTPClient_Generic(char* _serverAdress, char* _userName, char* _passWord, uint16_t _timeout = 10000);
	Serial.begin( 115200 );
	while (!Serial && millis() < 5000);
	Serial.print(F("\nStarting FTPClient_ListFiles on "));
	//Serial.print(BOARD_NAME);
	//Serial.print(F(" with "));
	//Serial.println(SHIELD_TYPE);
	Serial.println(FTPCLIENT_GENERIC_VERSION);
	WiFi.begin( WIFI_SSID, WIFI_PASS );
	Serial.print("Connecting WiFi, SSID = ");
	Serial.println(WIFI_SSID);
	while (WiFi.status() != WL_CONNECTED)
		Serial.print(".");
	Serial.print("\nIP address: ");
#if (ESP32)
	Serial.print("Max Free Heap: ");
	Serial.println(ESP.getMaxAllocHeap());
#endif
	//Change directory
	ftp.ChangeWorkDir(dirName);
	// Get the file size
	String       list[128];
	// Get the directory content in order to allocate buffer
	// my server response => type=file;modify=20190101000010;size=18; helloworld.txt
	ftp.ContentListWithListCommand("", list);
	for (uint16_t i = 0; i < sizeof(list); i++)
		if (list[i].length() > 0)
			Serial.println(list[i]);
	//Create a new Directory
	ftp.InitFile(COMMAND_XFER_TYPE_BINARY);
	//ftp.RemoveDir(newDirName);
	ftp.MakeDir(newDirName);
	//Enter the directory
	ftp.ChangeWorkDir(newDirName);
	Serial.println("CloseConnection");
serial monitor displays
Starting FTPClient_ListFiles on FTPCLIENT_GENERIC v1.4.0
Connecting WiFi, SSID = xxxxxx
IP address: 192.168.1.211
Max Free Heap: 113792
hello_world.txt
myNewDir
my_new_dir
CloseConnection
the new directory myNewDir22 is created OK
if I run the program again
Connecting WiFi, SSID = xxxxxxxxxxxxx
hello_world.txt
myNewDir
myNewDir22
my_new_dir
CloseConnection
Thanks everyone.
Unfortunately, it does not work for me.
I think this is a problem of my FTP server configuration since I don't even manage to connect to it using FileZilla Server.
Is there another way (easy if possible :slight_smile: to send a file through WIFI using a MKR 1010 ? Perhaps by email every day at a certain time? Or using the MKR as a server and conneting to it via a webpage where I can download the file?
Thanks
Iforire
you could run an FTP server on the MKR1010 and connect to it with a remote FTP client
I have used ESP32_FTPServer may work on a MKR1010
Thanks everyone.
Since I wanted to save data without using a SD card, i've finally used a Google Sheets to save my data (here's the video I used: NodeMCU ESP8266 + Google Spreadsheet | NodeMCU Sends Data to Google Sheets Directly (No Third Party) - YouTube).
