Hi!
I have been trying to programm my Arduino MKR WiFi 1010 for the last couple of weeks and I keep getting stuck. Firmware is 1.3.0 (latest as of writing), certificates for relevant webpages are installed.
I am running a webserver on the LAN and at the same time want to question a web-API periodically. What keeps happening (after some time) is, that after the request to the web-API is made (via connectSSL()) the webserver reports an available() client and the answer of the web-API lands in the wrong buffer.
After some time, the Webserver is not reachable anymore and the device hangs.
I made a MWE which is basically a combination of the WiFiSSLClient and the SimpleWebServerWiFI examples. I can make the error happen in under 30 Seconds.
#include <SPI.h>
#include <WiFiNINA.h>
#include "settings.h" // char[] arrays: ssid, pass, apiKey, lat, lon
int wifi_status = WL_IDLE_STATUS;
// Initialize the Wifi client library
WiFiSSLClient api_client;
// server address:
char apiserver[] = "www.google.com";
char api_response[8000] = {0};
unsigned long api_lastConnectionTime = 0; //TODO // last time you connected to the server, in milliseconds
unsigned long api_epochOffset = 0;
unsigned long api_lastCall_millis = 0;
unsigned long secs_today_in15mins = 0;
unsigned long api_interval = 30L * 1000L; // try every 30 seconds at first
unsigned long api_poweron_days = 0;
int api_parse_result = 0;
WiFiServer webserver(80);
bool wifi_noConnection = false;
unsigned long wifi_lastTry_millis = 0;
//Initialize serial and wait for port to open:
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
// attempt to connect to Wifi network:
wifi_status = WiFi.status();
while (wifi_status != WL_CONNECTED && (!wifi_lastTry_millis || wifi_lastTry_millis + 10000 < millis()))
wifi_noConnection = true;
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network.
wifi_status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
wifi_lastTry_millis = millis();
if(wifi_status == WL_CONNECTED && wifi_noConnection)
// you're connected now, so print out the status:
printWifiStatus();
//begin listening
webserver.begin();
// everything after here is useless without wifi
if(wifi_status == WL_CONNECTED)
bool api_currentLineIsBlank = true;
int pos = 0;
bool first_read = true;
while (api_client.available())
if(first_read)
//this is the first time, log event
Serial.println("api incomming");
first_read = false;
char c = api_client.read();
Serial.print(c);
if(api_parse_result) //this char is the first after the empty newline
if(pos >= sizeof(api_response))
api_response[pos] = c;
++pos;
if (c == '\n' && api_currentLineIsBlank)
api_parse_result = 1; //this line is still \n
if (c == '\n')
// you're starting a new line
else if (c != '\r')
// you've gotten a character on the current line
api_currentLineIsBlank = false;
//terminate with null byte
pos = sizeof(api_response) - 1;
api_response[pos] = 0x0;
Serial.print("api parse turn ");
Serial.println(api_parse_result);
//parse here
++api_parse_result;
if(api_parse_result && !api_client.available())
Serial.println("disconnecting from server");
api_client.stop();
// listen for incoming clients
WiFiClient webserver_client = webserver.available();
if (webserver_client)
Serial.println("client connected");
// an http request ends with a blank line
bool currentLineBlank = true;
while (webserver_client.connected())
if (webserver_client.available())
char c = webserver_client.read();
if (c == '\n')
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLineBlank)
// send a standard http response header
webserver_client.println("HTTP/1.1 200 OK");
webserver_client.println("Content-Type: text/html");
webserver_client.println("Connection: close"); // the connection will be closed after completion of the response
webserver_client.println();
webserver_client.println("<!DOCTYPE HTML>");
webserver_client.println("<html>");
webserver_client.println("<head>");
webserver_client.println("<meta charset=\"utf-8\">");
webserver_client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">");
webserver_client.println("</head>");
webserver_client.println("<h1>Website</h1>");
webserver_client.println("</html>");
else if (c != '\r')
currentLineBlank = false;
// close the connection:
webserver_client.stop();
Serial.println("client disconnected");
if(api_lastConnectionTime < (double)millis() - (double)api_interval)
Serial.println("api requesting");
// send out request to weather API
api_lastCall_millis = millis();
httpRequest();
// this method makes a HTTP connection to the server:
void httpRequest()
// close any connection before send a new request.
// This will free the socket on the WiFi shield
api_client.stop();
// if there's a successful connection:
if (api_client.connectSSL(apiserver, 443))
Serial.println("connecting...");
// send the HTTP PUT request:
api_client.println("GET / HTTP/1.1");
api_client.println("Host: www.google.com");
api_client.println("Connection: close");
api_client.println();
// note the time that the connection was made:
api_lastConnectionTime = millis();
// if you couldn't make a connection:
Serial.println("connection failed");
void printWifiStatus()
//left out. Same as example
Here is the serial output. I make several connections to the device, the last at 18:05:21.420. After that the answer from the webclient ends up in the wrong buffer.
18:05:13.938 -> Attempting to connect to SSID: ***
18:05:14.141 -> ***
18:05:14.141 -> IP Address: 192.168.178.76
18:05:14.141 -> signal strength (RSSI):-35 dBm
18:05:17.103 -> client connected
18:05:17.137 -> client disconnected
18:05:17.340 -> client connected
18:05:17.375 -> client disconnected
18:05:17.375 -> client connected
18:05:17.409 -> client disconnected
18:05:17.443 -> client connected
18:05:17.443 -> client disconnected
18:05:17.477 -> client connected
18:05:17.511 -> client disconnected
18:05:19.461 -> client connected
18:05:19.494 -> client disconnected
18:05:20.406 -> client connected
18:05:20.406 -> client disconnected
18:05:21.420 -> client connected
18:05:21.453 -> client disconnected
18:05:29.056 -> api requesting
18:05:33.568 -> connecting...
18:05:33.635 -> client connected
18:05:33.703 -> client disconnected
The full code of my project is here: GitHub - Mettbrot/giessbert_wifi
What I tried:
- making variables global
- removing all uses of String from Sketch
- smaller buffer size api_response[2000]. The MKR has 32Kb SRAM though.
- delay(500) after httpRequest()
It all did not work.
Any ideas?
