MKR WiFi 1010 halts on I2C Wire.begin(n) - unable to enumerate Address
The MKR WiFi 1010 seems unable to have an I2C address assigned. as the code halts. If no address is assigend in Wire.begin(), it works.
// Wire Slave Receiver
// by Nicholas Zambetti <http://www.zambetti.com>
// Demonstrates use of the Wire library
// Receives data as an I2C/TWI slave device
// Refer to the "Wire Master Writer" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
  Wire.begin(10);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  Serial.begin(9600);           // start serial for output
  pinMode(13,OUTPUT);
  delay(100);
  digitalWrite(13,HIGH);
  delay(100);
  digitalWrite(13,LOW);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany)
  while(1 < Wire.available()) // loop through all but the last
    char c = Wire.read(); // receive byte as a character
    Serial.print(c);         // print the character
  int x = Wire.read();    // receive byte as an integer
  Serial.println(x);         // print the integer
Found out the ATSAMD is incompatible with multimaster and Wire library
