I've read at the FAQs that the 5V pin outputs 5V from the board when powered from the USB connector or from the VIN pin. It is unregulated and the voltage is taken directly from the inputs
As I understand, I should be able to supply a 80mA device although the specs say that the max current for pin is 7mA... right?
The device I want to power specifies an inrush current of 600mA, would this fry the board?
The sensor and the board would only have one outlet available so I have to devise a way to power both with the same 5V adapter but since I have 0 experiencie in HW I wanted to keep it as simple as possible. Being realist I've no idea of what I'm doing :)))))
Then 80mA is to much for the board?
It would sustain 600mA for just a second at start up.
