MKR Wifi 1010 + MKR Evn Shied r2 - temperature issues
I am working with a pair of Arduino MKR boards. The first is the Wifi 1010, the second is the ENV Shield R2. Temperature and relative humidity sensors are connected to wifimodule which transmit to Arduino cloud. The problem is the temperature detection is higher than normal by 4 or 5 degree celsius. I hae tried multiple solutions, even with Arduino help desk. The best solution is altering the script to insert a shift for getting proper results.The system is currently powered by a professional power supply that delivers 7 volts. This is the voltage that allows the system to be connected via wifi. By lowering the voltage, the connection is not stable. What I would like to do to distance the two boards and connect them via a breadboard. I don't know which pins to connect to make it work.
