MKR WIFI 1010 websockets server
I am trying to setup a websocket server on a MKR wifi 1010. I have a simple client setup and working but as soon as I add this line:
#include <WebSocketsServer.h>
I get the error:
\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:243:56: error: macro “min” passed 3 arguments, but takes just 2
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
\arduino\tools\arm-none-eabi-gcc\7-2017q4\arm-none-eabi\include\c++\7.2.1\bits\stl_algobase.h:265:56: error: macro “max” passed 3 arguments, but takes just 2
max(const _Tp& __a, const _Tp& __b, _Compare __comp)
I’m using
name=WiFiNINA
version=1.5.0
name=WebSockets
version=2.2.0
author=Markus Sattler
#include <WiFiNINA.h>
// #include <WebSocketsServer.h>
const char WIFI_SSID[] = "wifi"; // WiFI ssid
const char WIFI_PASS[] = "password"; //WiFI password
WiFiClient net;
int status = WL_IDLE_STATUS;
  Serial.print("checking wifi...");
  while ( status != WL_CONNECTED) {
    status = WiFi.begin(WIFI_SSID, WIFI_PASS);
    Serial.print(".");
  Serial.println("\nconnected to WiFi!\n");
Can anyone help me get past this hurdle?
Thank you,
I guess you're using this library. Your platform isn't (yet) supported by this library.
Thanks Pylon for your response.
Is there any library that supports WebSocketsServer on the MKR 1010 WiFi?
I didn't try it with the MKR1010 but the ArduinoWebsockets library by Gil Maimon (available in the IDE library manager) should work with an network client.
