Mkr wifi 1010 with mkr env shield
Hello, i am currently using 2 mkr wifi 1010 to send and recieve something on a topic. The sender of those two has an mkr env shiel. My problem is that the sender won't send anything.
screenshot of the serial monitor:
My code:
#include <Arduino_MKRENV.h>
#include <ArduinoMqttClient.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
WiFiClient wifiClient;
MqttClient mqttClient(wifiClient);
const char broker[] = "test.mosquitto.org";
int port = 1883;
const char topic[] = "Temperature";
const char topic2[] = "Humidity";
const char topic3[] = "Pressure";
//set interval for sending messages (milliseconds)
const long interval = 8000;
unsigned long previousMillis = 0;
float t;
float h;
float pr;
int count = 0;
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ;  // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to Wifi network:
  Serial.print("Attempting to connect to WPA SSID: ");
  Serial.println(ssid);
  while (WiFi.begin(ssid, pass) != WL_CONNECTED) {
    // failed, retry
    Serial.print(".");
    delay(5000);
  Serial.println("You're connected to the network");
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
  if (!mqttClient.connect(broker, port)) {
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    while (1)
  Serial.println("You're connected to the MQTT broker!");
  t = ENV.readTemperature();
  h = ENV.readHumidity();
  pr = ENV.readPressure();
  Serial.println(t);
  // call poll() regularly to allow the library to send MQTT keep alive which
  // avoids being disconnected by the broker
  mqttClient.poll();
  if (currentMillis - previousMillis >= interval) {
    // save the last time a message was sent
    //record random value from A0, A1 and A2
    Serial.print("Sending message to topic: ");
    Serial.println(topic);
    Serial.println(t);
    Serial.println(topic2);
    Serial.println(h);
    Serial.println(topic3);
    Serial.println(pr);
    // send message, the Print interface can be used to set the message contents
    mqttClient.beginMessage(topic);
    mqttClient.print(t);
    mqttClient.endMessage();
    mqttClient.beginMessage(topic2);
    mqttClient.print(h);
    mqttClient.beginMessage(topic3);
    mqttClient.print(pr);
I was using this tutorial: https://docs.arduino.cc/tutorials/mkr-wifi-1010/mqtt-device-to-device
Can someone help?
I cannot see the ENV.begin() call in your setup(). That call is mandatory.
