I just recieved my MKR WiFi1010 and hooked it up to my laptop. The board shows up in my port list. I downloaded the package for SAMD board via the manager (the description say it also for my board) but it does not show up in the list. I tried instaling a fresh IDE 1.8.7 but still nothing. Can someone help..
I fixed it after removing the package a couple of times. I thing there was one installed with the same name but different support.
Why is it that if I uninstall the ide and re install it the installedd boards remain.. Doesn't the uninstall remove everything?
Tady:
Almost certainly the problem was that you had an outdated version of Arduino SAMD Boards installed. Only the latest version has the MKR 1010 board. But I guess we'll never know for sure now.
Tady:
No. It only removes the Arduino IDE installation. The hardware packages you install via Boards Manager are installed to a different location on your computer that is not touched by the uninstall.
After playing around with the wifi I suddenly got a unknown device descriptor... I tried several different usb cables, different usb ports, restarted the computer. It stopped working. Is my board a goner???
I cannot believe it that the board started having problem after 2 hours of playing around. On top of that I didn't even connect any leds or modules
Tady:
Idon't know what happened but I pressed RESET twice in a row and it re-booted. It works now
that is how it works. the USB is handled by he CPU. with wrong sketch it becomes unresponsive. the 'reset double click' activates the build-in bootloader
