Hello all,
I'm using an Arduino ZERO + MKR Eth Shield.
I can connect and post to a MQTT server but now I would like to connect to a MQTT server (CloudMqtt) that accept :
SSL Port
Or Websockets Port (TLS only)
And I fail on that error :
2020-04-07 10:24:39: Socket error on client <unknown>, disconnecting.
2020-04-07 10:24:39: New connection from 109.89.27.173 on port 23932.
2020-04-07 10:24:44: OpenSSL Error: error:140940E5:SSL routines:SSL3_READ_BYTES:ssl handshake failure
I get a lot of information from here : Arduino MKR 10xx, ETH Shield and Amazon Web Services: Safe MQTT with SSL and Certificate
But I don't want to user a certificat to connect but just user password
On my computer with MQTT SPy I just select theses option :
m23.cloudmqtt.com:33932 Websocket, TLSv1.2
- I check user authentication and I put user/pass
No need of certificate.
Here is what I try on the arduino :
Could you please help me ? Any Idea ?
#include <ArduinoBearSSL.h>
#include <ArduinoMqttClient.h>
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
const char broker[] = "m23.cloudmqtt.com";
#define mqttport 33932 //13932
#define AUTHTOKEN "XXXXXXX" //my password
#define AUTHMETHOD "XXXXXXX" // My user
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// time service
unsigned int localPort = 8888; // local port to listen for UDP packets
const char timeServer[] = "time.nist.gov"; // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
BearSSLClient sslClient(client); // Used for SSL/TLS connection, integrates with ECC508
MqttClient mqttClient(sslClient);
unsigned long lastMillis = 0;
delay(5000);
Serial.println("End delay 5000");
pinMode(4, OUTPUT);
digitalWrite(4, HIGH);
Ethernet.init(5); // MKR ETH shield
while (!Serial);
// start Ethernet and UDP
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
} else if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// no point in carrying on, so do nothing forevermore:
while (true) {
delay(1);
Serial.print("L'adresse IP du shield Ethernet est :" );
Serial.println(Ethernet.localIP());
Udp.begin(localPort);
getTime();
// Set a callback to get the current time
// used to validate the servers certificate
//ArduinoBearSSL.onGetTime(getTime);
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
//if (sslClient.connect("m23.cloudmqtt.com", 33932))
Serial.println("connected to cloudmqtt");
mqttClient.setId("clientId");
mqttClient.setUsernamePassword(AUTHMETHOD,AUTHTOKEN); //user pass
mqttClient.onMessage(onMessageReceived);
Serial.println("test con sslclient");
////////////////////////// The programe loop Here beacause doesn't manage to connect
while (!mqttClient.connect(broker, 23932)) {
// failed, retry
Serial.print(".");
delay(5000);
Serial.println("You're connected to the MQTT broker");
if (!mqttClient.connected()) {
// MQTT client is disconnected, connect
connectMQTT();
// poll for new MQTT messages and send keep alives
mqttClient.poll();
// publish a message roughly every 5 seconds.
if (millis() - lastMillis > 5000) {
lastMillis = millis();
publishMessage();
unsigned long getTime() {
sendNTPpacket(timeServer); // send an NTP packet to a time server
unsigned long epoch = 0UL;
// wait to see if a reply is available
if (Udp.parsePacket()) {
// We've received a packet, read the data from it
Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
// the timestamp starts at byte 40 of the received packet and is four bytes,
// or two words, long. First, extract the two words:
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
// combine the four bytes (two words) into a long integer
// this is NTP time (seconds since Jan 1 1900):
unsigned long secsSince1900 = highWord << 16 | lowWord;
Serial.print("Seconds since Jan 1 1900 = ");
Serial.println(secsSince1900);
// now convert NTP time into everyday time:
Serial.print("Unix time = ");
// Unix time starts on Jan 1 1970. In seconds, that's 2208988800:
const unsigned long seventyYears = 2208988800UL;
// subtract seventy years:
epoch = secsSince1900 - seventyYears;
Serial.println(epoch);
return epoch;
// send an NTP request to the time server at the given address
void sendNTPpacket(const char * address) {
// set all bytes in the buffer to 0
memset(packetBuffer, 0, NTP_PACKET_SIZE);
// Initialize values needed to form NTP request
// (see URL above for details on the packets)
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
// 8 bytes of zero for Root Delay & Root Dispersion
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
// all NTP fields have been given values, now
// you can send a packet requesting a timestamp:
Udp.beginPacket(address, 123); // NTP requests are to port 123
Udp.write(packetBuffer, NTP_PACKET_SIZE);
Udp.endPacket();
void connectMQTT() {
Serial.print("Attempting to MQTT broker: ");
Serial.print(broker);
Serial.println(" ");
while (!mqttClient.connect(broker, mqttport)) {
// failed, retry
Serial.print(".");
delay(5000);
// subscribe to a topic
mqttClient.subscribe("arduino/incoming");
void publishMessage() {
Serial.println("Publishing message");
// send message, the Print interface can be used to set the message contents
mqttClient.beginMessage("arduino/outgoing");
mqttClient.print("{\n\"message\": \"hello\",\n\"testdata\": ");
mqttClient.print(millis());
mqttClient.print("\n}");
mqttClient.endMessage();
void onMessageReceived(int messageSize) {
// we received a message, print out the topic and contents
Serial.print("Received a message with topic '");
Serial.print(mqttClient.messageTopic());
Serial.print("', length ");
Serial.print(messageSize);
Serial.println(" bytes:");
// use the Stream interface to print the contents
while (mqttClient.available()) {
Serial.print((char)mqttClient.read());
