MKR1000 disconnects from wifi when I add the Scheduler code
Hello,
I am using Arduino IoT with MKR1000. Everything is running fine, and I can control arduino outputs over wifi, until I add the scheduler.
Upon adding the scheduler, everything compiles and I am able to upload the sketch, but then the MKR1000 stops connecting to wifi, so I am unable to control it. Once I remove the scheduler, the MKR1000 starts connecting to wifi. Need help on this.
Here is the code:
#include "thingProperties.h"
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
pinMode(LED_BUILTIN, OUTPUT);
light_scheduler = false;
ArduinoCloud.update();
if(scheduler.isActive()){
digitalWrite(LED_BUILTIN, HIGH);
else{
digitalWrite(LED_BUILTIN, LOW);
void onSchedulerChange() {
