MKR1000 Doesn't Run "Blink" Sketch
I bought and MKR1000 and installed all the drivers on my computer. I am running Linux on a Chromebook, and I have the Arduino IDE 1.6.12.
When I upload the sketch to the board, I get this response (below) but the code itself doesn’t appear to run. The LED does not blink.
I would appreciate any help anyone has to offer. Thanks.
Sketch uses 9,056 bytes (3%) of program storage space. Maximum is 262,144 bytes.
Atmel SMART device 0x10010005 found
Device       : ATSAMD21G18A
Chip ID      : 10010005
Version      : v2.0 [Arduino:XYZ] Nov 24 2015 11:34:08
Address      : 8192
Pages        : 3968
Page Size    : 64 bytes
Total Size   : 248KB
Planes       : 1
Lock Regions : 16
Locked       : none
Security     : false
Boot Flash   : true
BOD          : true
BOR          : true
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.854 seconds
Write 9312 bytes to flash (146 pages)
[=============                 ] 43% (64/146 pages)
[==========================    ] 87% (128/146 pages)
[==============================] 100% (146/146 pages)
done in 0.070 seconds
Verify 9312 bytes of flash with checksum.
Verify successful
done in 0.008 seconds
CPU reset.
I can only presume your sketch does something with an LED ?
Include it if you don't mind ?
The console says it sent up to the MKR just fine so maybe a code issue.
Here's the code, copied from: https://www.arduino.cc/en/tutorial/blink
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN takes care
  of use the correct LED pin whatever is the board used.
  If you want to know what pin the on-board LED is connected to on your Arduino model, check
  the Technical Specs of your board  at https://www.arduino.cc/en/Main/Products
  This example code is in the public domain.
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
