MKR1000 Error Compiling
Hello,
I just bought my first MKR1000, and am trying out the "Love You Pillow" project.
I have installed the four libraries and the SAMD board.
However, I have problem uploading the FirmwareUpdater example onto the board after uploading the api.telegram.cc:443 certificate.
This is the error message I got:
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino MKR1000"
Sketch uses 16248 bytes (6%) of program storage space. Maximum is 262144 bytes.
Atmel SMART device 0x10010005 found
Device       : ATSAMD21G18A
Chip ID      : 10010005
Version      : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
Address      : 8192
Pages        : 3968
Page Size    : 64 bytes
Total Size   : 248KB
Planes       : 1
Lock Regions : 16
Locked       : none
Security     : false
Boot Flash   : true
BOD          : true
BOR          : true
Arduino      : FAST_CHIP_ERASE
Arduino      : FAST_MULTI_PAGE_WRITE
Arduino      : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
done in 0.849 seconds
Write 16568 bytes to flash (259 pages)
[=======                       ] 24% (64/259 pages)
[==============                ] 49% (128/259 pages)
[======================        ] 74% (192/259 pages)
SAM-BA operation failed
An error occurred while uploading the sketch
[============================= ] 98% (256/259 pages)
[==============================] 100% (259/259 pages)
done in 0.110 seconds
Verify 16568 bytes of flash with checksum.
Verify successful
done in 0.024 seconds
CPU reset.
option enabled in File -> Preferences.
Any help is appreciated. Thanks!
Do you have your MKR1000 connected to a USB 3 port on your computer? If so, connect it to a USB 2.0 port or to a USB 2.0 hub plugged into the USB 3 port.
pert:
Thanks for the reply.
I connected it to a USB 2.0 port. There were no errors compiling, but there were the same errors when uploading.
Is there anything that I am doing wrongly?
