I have an Arduino MKR1000 that I would like to use with WIfi Client Wifi101 and IRRemote lib.
IRRemore works for a while then stops. I found out that it might be because of using the same timer as wifi client. I found it is possible to change timers for IRRemote.
so I did:
If a timer is used by different libraries, you will get linker errors; that is what your link is solving. I'm not familiar with the MKR1000 but I think that it will help if you post your code (don't forget the code tags ).
#include <IRremote.hpp>
#include <WiFi101.h>
char ssid[] = "jebnato"; // your network SSID (name) between the " "
char pass[] = "***"; // your network password between the " "
#define IR_RECEIVE_PIN 1
WiFiClient client;
int status = WL_IDLE_STATUS; //connection status
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void enable_WiFi() {
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
void connect_WiFi() {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
Serial.println("starting");
enable_WiFi();
connect_WiFi();
printWifiStatus();
Serial.println("started");
IrReceiver.begin(IR_RECEIVE_PIN, false);
if (IrReceiver.decode()) {
Serial.println(IrReceiver.decodedIRData.decodedRawData);
if (IrReceiver.decodedIRData.decodedRawData == 2516879342) {
Serial.println("one");
if (IrReceiver.decodedIRData.decodedRawData == 2516748270) {
Serial.println("two");
IrReceiver.resume(); // Enable receiving of the next value
this is it. wifi connects, IR receives one or sometimes ten commands and then it hangs.
when you comment out
enable_WiFi();
connect_WiFi();
printWifiStatus();
IR works as expected. Simply IR can not coexist with wifi on this board or just for a little while;
