MKR1000 Not Being Able to Upload Blink
I recently purchased the engineering kit through Arduino and I'm currently trying to connect my MKR1000 to my computer and upload the blink program through my PC. I have triple checked everything and installed the Arduino IDE and the necessary drivers. The board and port are correct so I can't find any issues as I have done the outlined process multiple times. This is the error code that I receive.
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino MKR1000"
Sketch uses 11044 bytes (4%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM5, } / {} => {}
PORTS {} / {COM4, } => {COM4, }
Found upload port: COM4
C:\ProgramData\MATLAB\SupportPackages\R2019a\3P.instrset\arduinoide.instrset\idepkgs\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe -i -d --port=COM4 -U true -i -e -w -v C:\Users\LOGANR~1\AppData\Local\Temp\arduino_build_601187/Blink.ino.bin -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:43
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.655 seconds
Write 11188 bytes to flash (175 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[========== ] 36% (64/175 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
SAM-BA operation failed
[===================== ] 73% (128/175 pages)write(addr=0x20005000,size=0xbc0)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0xbc0)
[==============================] 100% (175/175 pages)
done in 0.096 seconds
Verify 11188 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 246c
checksumBuffer(start_addr=0x3000, size=0x1000) = 7553
checksumBuffer(start_addr=0x4000, size=0xbb4) = 54ec
Verify successful
done in 0.015 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
An error occurred while uploading the sketch
option enabled in File -> Preferences.
This is the code that I used.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
USB port was bad so it wasn't working. Figured it out.
