MKR1000 - SPARKFUN microSD Shield doesn't initialize
i have a MKR1000 connected to a microSD Shield by Sparkfun, respectively by MKR’s pin—>Shield’s pin:
  • 8—>11
  • 9—>13
  • 10—>12
and i try to execute the example sketch below, changing the SS_PIN setup like a read in other topics but it doesn’t work. Can anyone explain me what is wrong?
#include <SPI.h>
#include <SD.h>
File myFile;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  pinMode(SS_PIN, OUTPUT);
  digitalWrite(SS_PIN, HIGH);
  Serial.print("Initializing SD card...");
  if (!SD.begin()) {
    Serial.println("initialization failed!");
    Serial.println(SD.begin());
    return;
  Serial.println("initialization done.");
The SD card is 4GB, formatted FAT32, allocation space 4096 byte.
Thanks to everyone
Did you ever solve this issue?
I am having the same problem with another microSD Shield and I very much would like to add a SD card to my MKR1000. I would have no problem getting another SD card reader if I know it works.
Thanks
José
Hi there -
I'm also trying to get the SparkFun microSD breakout board working with an MKR1000 - did you guys ever get it working? If so, would you mind sharing which pins to use?
Thanks,
Mike
Someone have solved this problem? I've lost a couple of days searching for some solution, but every time the error the error is the same:
Initializing SD card...initialization failed. Things to check:
* is a card inserted?
* is your wiring correct?
* did you change the chipSelect pin to match your shield or module?
