I'm struggling to find the answers I need. I know the MKR has SERCOM. I'm trying to alter this code to work with my Sparkfun RFID kit. Since this board doesn't use Softwareserial how can I define the pins properly to allow reading of the card? Thanks in advance. I'm a rookie just getting my feet wet.
Cheers,
Krispy
RFID-powered lockbox
Written by: acavis, 3/31/2015
Modified: Ho YUN "Bobby" Chan @ SparkFun Electronics Inc., 11/10/2017
Inspired by & partially adapted from
http://bildr.org/2011/02/rfid-arduino/
Description: This sketch will move a servo when
a trusted tag is read with the
ID-12/ID-20 RFID module
----------HARDWARE HOOKUP----------
PINOUT FOR SERVO MOTOR
Servo Motor ----- Arduino
GND GND
Vcc 5V
SIG D9
PINOUT FOR SPARKFUN RFID USB READER
Arduino ----- RFID module
5V VCC
GND GND
D2 TX
PINOUT FOR SPARKFUN RFID BREAKOUT BOARD
5V VCC
GND GND
GND FORM
D2 D0
Optional: If using the breakout, you can also
put an LED & 330 ohm resistor between
the RFID module's READ pin and GND for
a "card successfully read" indication.
Note: Make sure to GND the FORM pin to enable the ASCII output format.
#include <SoftwareSerial.h>
#include <Servo.h>
// Choose two pins for SoftwareSerial
SoftwareSerial rSerial(2, 3); // RX, TX
// Make a servo object
Servo lockServo;
// Pick a PWM pin to put the servo on
const int servoPin = 9;
// For SparkFun's tags, we will receive 16 bytes on every
// tag read, but throw four away. The 13th space will always
// be 0, since proper strings in Arduino end with 0
// These constants hold the total tag length (tagLen) and
// the length of the part we want to keep (idLen),
// plus the total number of tags we want to check against (kTags)
const int tagLen = 16;
const int idLen = 13;
const int kTags = 4;
// Put your known tags here!
char knownTags[kTags][idLen] = {
"111111111111",
"444444444444",
"555555555555",
"7A005B0FF8D6"
// Empty array to hold a freshly scanned tag
char newTag[idLen];
// Starts the hardware and software serial ports
rSerial.begin(9600);
// Attaches the servo to the pin
lockServo.attach(servoPin);
// Put servo in locked position
// Note: Value may need to be adjusted
// depending on servo motor
lockServo.write(0);
// Counter for the newTag array
int i = 0;
// Variable to hold each byte read from the serial buffer
int readByte;
// Flag so we know when a tag is over
boolean tag = false;
// This makes sure the whole tag is in the serial buffer before
// reading, the Arduino can read faster than the ID module can deliver!
if (rSerial.available() == tagLen) {
tag = true;
if (tag == true) {
while (rSerial.available()) {
// Take each byte out of the serial buffer, one at a time
readByte = rSerial.read();
/* This will skip the first byte (2, STX, start of text) and the last three,
ASCII 13, CR/carriage return, ASCII 10, LF/linefeed, and ASCII 3, ETX/end of
text, leaving only the unique part of the tag string. It puts the byte into
the first space in the array, then steps ahead one spot */
if (readByte != 2 && readByte!= 13 && readByte != 10 && readByte != 3) {
newTag[i] = readByte;
i++;
// If we see ASCII 3, ETX, the tag is over
if (readByte == 3) {
tag = false;
// don't do anything if the newTag array is full of zeroes
if (strlen(newTag)== 0) {
return;
else {
int total = 0;
for (int ct=0; ct < kTags; ct++){
total += checkTag(newTag, knownTags[ct]);
// If newTag matched any of the tags
// we checked against, total will be 1
if (total > 0) {
// Put the action of your choice here!
// I'm going to rotate the servo to symbolize unlocking the lockbox
Serial.println("Success!");
lockServo.write(180);
else {
// This prints out unknown cards so you can add them to your knownTags as needed
Serial.print("Unknown tag! ");
Serial.print(newTag);
// Once newTag has been checked, fill it with zeroes
// to get ready for the next tag read
for (int c=0; c < idLen; c++) {
newTag[c] = 0;
// This function steps through both newTag and one of the known
// tags. If there is a mismatch anywhere in the tag, it will return 0,
// but if every character in the tag is the same, it returns 1
int checkTag(char nTag[], char oTag[]) {
for (int i = 0; i < idLen; i++) {
if (nTag[i] != oTag[i]) {
return 0;
return 1;
