MKR1000. Wifi101 ARP request
Does anybody know a way to implement an ARP request in this environment? Is there any library or support that I can use or should I have to implement it from zero?
Thank you very much!
Hi @sontono,
I quickly scanned the ASF code from Atmel that the WiFi101 library is built on top of, I did not see anything to trigger or make ARP requests.
There is a function called “m2m_wifi_send_wlan_pkt” that you might be able to do this. Let me know if this is helpful, also if you get things working, it would be great if you could submit a pull request!
