I am trying to send ±5500 bytes via an HTTPS POST using the Arduino MKR1010. The code is working if I only include the first four FFT strings (runout_fft1, runout_fft2, runout_fft3, runout_fft4). If I try to send the "runout_fft5" the client.print command returns 0. Meaning it did not send the last string. And I don't see any incoming request on:
I don't see the problem with sending the last FFT string (runout_fft5).
The response when sending 4 FFT strings is:
postByteCount: 4426
Attempting to connect to SSID: IoT
Connected to wifi
SSID: IoT
IP Address: 192.168.11.154
signal strength (RSSI):-57 dBm
800
800
842
880
Server response:
Stop the client
When I send 5 FFT strings:
postByteCount: 5283
Connected to wifi
SSID: IoT
signal strength (RSSI):-48 dBm
800
800
842
880
0
Server response:
Stop the client
When I test the functionality with an online API tester reqbin.com/ I can send up to 6869 bytes.
My code:
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets_ldm.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;
char server[] = "runout.requestcatcher.com"; // name address for aeuw-prod (using DNS)
WiFiSSLClient client;
// POST DATA
String runout = "bench=ABC-DEF-001&"
"scaife=ABC-DEF-001&"
"delta=8.01&"
"fft_peak_hz=50.02&"
"fft_peak_mag=200.12&"
"rssi=-81&"
"ip=192.168.178.55&"
"snm=255.255.255.0&"
"gw=192.168.178.1&"
"ssid=SSIDname&"
"battery=1435.23&";
String runout_data = "ro0=15.10&ro1=15.10&ro2=15.10&ro3=15.10&ro4=15.10&ro5=15.10&ro6=15.10&ro7=15.10&ro8=15.10&"
"ro9=15.10&ro10=15.10&ro11=15.10&ro12=15.10&ro13=15.10&ro14=15.10&ro15=15.10&ro16=15.10&ro17=15.10&ro18=15.10&ro19=15.10&"
"ro20=15.10&ro21=15.10&ro22=15.10&ro23=15.10&ro24=15.10&ro25=15.10&ro26=15.10&ro27=15.10&ro28=15.10&ro29=15.10&ro30=15.10&"
"ro31=15.10&ro32=15.10&ro33=15.10&ro34=15.10&ro35=15.10&ro36=15.10&ro37=15.10&ro38=15.10&ro39=15.10&ro40=15.10&ro41=15.10&"
"ro42=15.10&ro43=15.10&ro44=15.10&ro45=15.10&ro46=15.10&ro47=15.10&ro48=15.10&ro49=15.10&ro50=15.10&ro51=15.10&ro52=15.10&"
"ro53=15.10&ro54=15.10&ro55=15.10&ro56=15.10&ro57=15.10&ro58=15.10&ro59=15.10&ro60=15.10&ro61=15.10&ro62=15.10&ro63=15.10&"
"ro64=15.10&ro65=15.10&ro66=15.10&ro67=15.10&ro68=15.10&ro69=15.10&ro70=15.10&ro71=15.10&ro72=15.10&ro73=15.10&ro74=15.10&"
"ro75=15.10&ro76=15.10&ro77=15.10&ro78=15.10&ro79=15.10&ro80=15.10&ro81=15.10&ro82=15.10&ro83=15.10&ro84=15.10&";
String runout_fft1 = "x0=12.34&y0=56.78&x1=12.34&y1=56.78&x2=12.34&y2=56.78&x3=12.34&y3=56.78&x4=12.34&y4=56.78"
"&x5=12.34&y5=56.78&x6=12.34&y6=56.78&x7=12.34&y7=56.78&x8=12.34&y8=56.78&x9=12.34&y9=56.78&x10=12.34&y10=56.78&x11=12.34"
"&y11=56.78&x12=12.34&y12=56.78&x13=12.34&y13=56.78&x14=12.34&y14=56.78&x15=12.34&y15=56.78&x16=12.34&y16=56.78&x17=12.34"
"&y17=56.78&x18=12.34&y18=56.78&x19=12.34&y19=56.78&x20=12.34&y20=56.78&x21=12.34&y21=56.78&x22=12.34&y22=56.78&x23=12.34"
"&y23=56.78&x24=12.34&y24=56.78&x25=12.34&y25=56.78&x26=12.34&y26=56.78&x27=12.34&y27=56.78&x28=12.34&y28=56.78&x29=12.34"
"&y29=56.78&x30=12.34&y30=56.78&x31=12.34&y31=56.78&x32=12.34&y32=56.78&x33=12.34&y33=56.78&x34=12.34&y34=56.78&x35=12.34"
"&y35=56.78&x36=12.34&y36=56.78&x37=12.34&y37=56.78&x38=12.34&y38=56.78&x39=12.34&y39=56.78&x40=12.34&y40=56.78&";
String runout_fft2 = "x41=12.34&y41=56.78&x42=12.34&y42=56.78&x43=12.34&y43=56.78&x44=12.34&y44=56.78&x45=12.34&y45=56.78&"
"x46=12.34&y46=56.78&x47=12.34"
"&y47=56.78&x48=12.34&y48=56.78&x49=12.34&y49=56.78&x50=12.34&y50=56.78&x51=12.34&y51=56.78&x52=12.34&y52=56.78&x53=12.34&"
"y53=56.78&x54=12.34&y54=56.78&x55=12.34&y55=56.78&"
"x56=12.34&y56=56.78&x57=12.34&y57=56.78&x58=12.34&y58=56.78&x59=12.34&y59=56.78&x60=12.34&y60=56.78&x61=12.34&y61=56.78&"
"x62=12.34&y62=56.78&x63=12.34&y63=56.78&x64=12.34&y64=56.78&x65=12.34&y65=56.78&x66=12.34&y66=56.78&x67=12.34&y67=56.78&"
"x68=12.34&y68=56.78&x69=12.34&y69=56.78&x70=12.34&y70=56.78&x71=12.34&y71=56.78&x72=12.34&y72=56.78&x73=12.34&y73=56.78&"
"x74=12.34&y74=56.78&x75=12.34&y75=56.78&x76=12.34&y76=56.78&x77=12.34&y77=56.78&x78=12.34&y78=56.78&x79=12.34&y79=56.78&"
"x80=12.34&y80=56.78&";
String runout_fft3 = "x81=12.34&y81=56.78&x82=12.34&y82=56.78&x83=12.34&y83=56.78&x84=12.34&y84=56.78&x85=12.34&y85=56.78&"
"x86=12.34&y86=56.78&x87=12.34&y87=56.78&x88=12.34&y88=56.78&x89=12.34&y89=56.78&x90=12.34&y90=56.78&x91=12.34&y91=56.78&"
"x92=12.34&y92=56.78&x93=12.34&y93=56.78&x94=12.34&y94=56.78&x95=12.34&y95=56.78&x96=12.34&y96=56.78&x97=12.34&y97=56.78&"
"x98=12.34&y98=56.78&x99=12.34&y99=56.78&x100=12.34&y100=56.78&x101=12.34&y101=56.78&x102=12.34&y102=56.78&x103=12.34&y"
"103=56.78&x104=12.34&y104=56.78&x105=12.34&"
"y105=56.78&x106=12.34&y106=56.78&x107=12.34&y107=56.78&x108=12.34&y108=56.78&x109=12.34&y109=56.78&x110=12.34&y110=56.78&"
"x111=12.34&y111=56.78&x112=12.34&y112=56.78&x113=12.34&y113=56.78&x114=12.34&y114=56.78&x115=12.34&y115=56.78&x116=12.34&"
"y116=56.78&x117=12.34&y117=56.78&x118=12.34&y118=56.78&x119=12.34&y119=56.78&x120=12.34&y120=56.78&";
String runout_fft4 = "x121=12.34&y121=56.78&"
"x122=12.34&y122=56.78&x123=12.34&y123=56.78&x124=12.34&y124=56.78&x125=12.34&y125=56.78&x126=12.34&y126=56.78&x127=12.34&"
"y127=56.78&x128=12.34&y128=56.78&x129=12.34&y129=56.78&x130=12.34&y130=56.78&x131=12.34&y131=56.78&x132=12.34&y132=56.78&"
"x133=12.34&y133=56.78&x134=12.34&y134=56.78&x135=12.34&y135=56.78&x136=12.34&y136=56.78&x137=12.34&y137=56.78&x138=12.34&"
"y138=56.78&x139=12.34&y139=56.78&x140=12.34&y140=56.78&x141=12.34&y141=56.78&x142=12.34&y142=56.78&x143=12.34&y143=56.78&"
"x144=12.34&y144=56.78&x145=12.34&y145=56.78&x146=12.34&y146=56.78&x147=12.34&y147=56.78&x148=12.34&y148=56.78&x149=12.34&"
"y149=56.78&x150=12.34&y150=56.78&"
"x151=12.34&y151=56.78&x152=12.34&y152=56.78&x153=12.34&y153=56.78&x154=12.34&y154=56.78&x155=12.34&"
"y155=56.78&x156=12.34&y156=56.78&x157=12.34&y157=56.78&x158=12.34&y158=56.78&x159=12.34&y159=56.78&x160=12.34&y160=56.78&";
String runout_fft5 = "x161=12.34&y161=56.78&x162=12.34&y162=56.78&x163=12.34&y163=56.78&x164=12.34&y164=56.78&x165=12.34&y165=56.78&x166=12.34&"
"y166=56.78&x167=12.34&y167=56.78&x168=12.34&y168=56.78&x169=12.34&y169=56.78&x170=12.34&y170=56.78&x171=12.34&y171=56.78&"
"x172=12.34&y172=56.78&x173=12.34&y173=56.78&x174=12.34&y174=56.78&x175=12.34&y175=56.78&x176=12.34&y176=56.78&x177=12.34&"
"y177=56.78&x178=12.34&y178=56.78&x179=12.34&y179=56.78&x180=12.34&y180=56.78&x181=12.34&y181=56.78&x182=12.34&y182=56.78&"
"x183=12.34&y183=56.78&x184=12.34&y184=56.78&x185=12.34&y185=56.78&x186=12.34&y186=56.78&x187=12.34&y187=56.78&x188=12.34&"
"y188=56.78&x189=12.34&y189=56.78&x190=12.34&y190=56.78&x191=12.34&y191=56.78&x192=12.34&y192=56.78&x193=12.34&y193=56.78&"
"x194=12.34&y194=56.78&x195=12.34&y195=56.78&x196=12.34&y196=56.78&x197=12.34&y197=56.78&x198=12.34&y198=56.78&x199=12.34&"
"y199=56.78";
int postByteCount = 0;
// SETUP
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// POST LENGTH
postByteCount = runout.length() + runout_data.length() +
runout_fft1.length() +
runout_fft2.length() +
runout_fft3.length() +
runout_fft4.length() +
0;
Serial.print("postByteCount: ");
Serial.println(postByteCount);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWiFiStatus();
// POST
https_post(postByteCount);
// LOOP
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("Stop the client");
client.stop();
// do nothing forevermore:
while (true);
// FUNCTIONS
void https_post(int bytes_in_post) {
if (client.connectSSL(server, 443)) {
// Make a HTTP request:
client.println("POST /test HTTP/1.1");
client.println("Host: runout.requestcatcher.com");
client.println("Accept: */*");
client.println("Accept-Encoding: deflate, gzip");
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(bytes_in_post);
client.println(); // empty line
// POST
client.print(runout);
// Serial.println(runout);
// POST DATA
client.print(runout_data);
// POST FFT
Serial.println(client.print(runout_fft1));
Serial.println(client.print(runout_fft2));
Serial.println(client.print(runout_fft3));
Serial.println(client.print(runout_fft4));
// Serial.println(client.print(runout_fft5));
// READ RESPONSE
Serial.println("Server response: ");
char c = client.read();
Serial.println(c);
// STOP CLIENT
client.stop();
void printWiFiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print your board's GW IP address:
// IPAddress gw_ip = WiFi.gatewayIP();
// Serial.print("GW IP Address: ");
// Serial.println(gw_ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Any help is welcome!
