MKR1010 Wifi USBHost Library
I am working on trying to make a USB barcode scanner work with the USB port on the MKR1010 WiFi. I can successfully connect a mouse and a keyboard, but when I connect the scanner, which "emulates" a keyboard, it does not work. A USB keyboard works fine. I have messed with this for days, and I can see the different states the USBHost goes through. I believe the issue is the library can not identify the scanner as a known device type. I have seen several topics posted here on the same subject all a year or two old, and none have solutions. I am wondering if anyone has been successful and connecting a USB scanner to an MRK1010 Wifi. I gave up and coded a Bluetooth connection and have that working, but it will not work with the wifi connection, so I am back to the drawing board. Any help of status from others who are or have tried to solve the same solution would be great.
TIA
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
