Salve a tutti,
sto provando a realizzare una piccola stazione "meteo" che per ora legge solo umidità e temperatura con la board mkr1200.
Il codice che utilizzo è il seguente :
#include "SigFox.h"
#include "ArduinoLowPower.h"
#include "DHT.h"
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
#define DHTPIN 1 // What digital pin we're connected to
#define DHTTYPE DHT11
#define DEBUG true // Set DEBUG to false to disable serial prints
#define SLEEPTIME 15 * 60 * 1000 // Set the delay to 15 minutes (15 min x 60 seconds x 1000 milliseconds)
#define UINT16_t_MAX 65536
#define INT16_t_MAX UINT16_t_MAX/2
typedef struct __attribute__ ((packed)) sigfox_message {
int16_t moduleTemperature;
int16_t dhtTemperature;
uint16_t dhtHumidity;
uint8_t lastMessageStatus;
} SigfoxMessage;
// Stub for message which will be sent
SigfoxMessage msg;
DHT dht(DHTPIN, DHTTYPE);
if (DEBUG) {
// We are using Serial1 instead than Serial because we are going in standby
// and the USB port could get confused during wakeup. To read the DEBUG prints,
// connect pins 13-14 (TX-RX) to a 3.3V USB-to-serial converter
Serial1.begin(115200);
while (!Serial1) {}
if (!SigFox.begin()) {
// Something is really wrong, try rebooting
// Reboot is useful if we are powering the board using an unreliable power source
// (eg. solar panels or other energy harvesting methods)
reboot();
// Send module to standby until we need to send a message
SigFox.end();
if (DEBUG) {
// Enable DEBUG prints and LED indication if we are testing
SigFox.debug();
dht.begin();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
// Read temperature as Celsius (the default)
float t = dht.readTemperature();
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
msg.dhtTemperature = convertoFloatToInt16(t, 60, -60);
msg.dhtHumidity = convertoFloatToUInt16(h, 110);
if(DEBUG) {
Serial.print("Humidity: ");
Serial.print(h);
Serial.print(" %\t");
Serial.print("Temperature: ");
Serial.print(t);
Serial.print(" *C ");
// Start the module
SigFox.begin();
// Wait at least 30ms after first configuration (100ms before)
delay(100);
// We can only read the module temperature before SigFox.end()
t = SigFox.internalTemperature();
msg.moduleTemperature = convertoFloatToInt16(t, 60, -60);
// Clears all pending interrupts
SigFox.status();
delay(1);
SigFox.beginPacket();
SigFox.write((uint8_t*)&msg, 12);
msg.lastMessageStatus = SigFox.endPacket();
SigFox.end();
//Sleep for 15 minutes
LowPower.sleep(SLEEPTIME);
void reboot() {
NVIC_SystemReset();
while (1) ;
int16_t convertoFloatToInt16(float value, long max, long min) {
float conversionFactor = (float) (INT16_t_MAX) / (float)(max - min);
return (int16_t)(value * conversionFactor);
uint16_t convertoFloatToUInt16(float value, long max) {
float conversionFactor = (float) (UINT16_t_MAX) / (float)(max);
return (uint16_t)(value * conversionFactor);
Il problema è che non carica sul portale sigfox un messaggio ogni 15 min.
Se provo con l'esempio first configuration il messaggio arriva correttamente.
Qualcuno ha qualche idea?
