MKR1400gsm bootloader
Hello,
My MKR1400GSM is not recognized anymore by Windows 10 by an unknown reason. I think it has something to do with the bootloader. Other Arduino boards work fine at the same USB interface. How can I renew the bootloader program? Burn a bootloader with programmer Atmel SAM-ICE as in IDE 1.8.13 doesn't work. Thanks in advance.
I'm not familiar with the MKR family but I think that a double reset should invoke the boot loader. If so, you should see a fading L led and you can check in Windows device manager if something shows up when you double tap the reset button.
Based on that result, you know if you have to flash a new boot loader or not.
This is correct.
I did what you suggested. I see the fading LED. The MKR1400GSM connection changes nothing in
the device manager. With IDE 1.8.19 the port can't be seen. So I still don't know what's wrong with this expensive board. A Nano board on the same USB unterfaces works fine.
Make sure the USB cable is completely plugged into both the Arduino board and the PC.
You may have a damaged/defective or charge-only USB cable. Try a different cable.
Either of the above can result in the power connections being made (and thus LED lights on the board), but no data connections (and thus no port for the board).
Thank you very much. It seemed that I had 2 bad cables which made things confusing.
You are welcome. I'm glad to hear that you found the cause of the problem. Enjoy!
