I've used two different MKR1500 boards, with battery and without, three different antennas, a sim card from soracom and one from hologram, to rule out any hardware problems but the issue remains the same. As long as the board stays in one place, it will stay connected to the arduino iot cloud but as soon as I drive from work to home it will loose connection and not try to reconnect. This happens in either direction: if I power cycle the board at work then drive home, or start from home and drive to work. Any help is greatly appreciated as I don't know where to go from here.
I'm using the most basic code I can use to test to keep it simple.
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/160cc0f5-2ece-41eb-86a5-373f1f10e69e
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
bool lockStatus;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
String serialMessage;
// Initialize serial and wait for port to open:
Serial1.begin(115200);
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
while (Serial1.available()) {
delay(1);
serialMessage = Serial1.readString();
serialMessage.trim();
if(serialMessage == "doorsUnlocked"){
lockStatus = false;
if(serialMessage == "doorsLocked"){
lockStatus = true;
