I'm having trouble sending data to sigfox backend.
Here is ravdata from backend
07d007000003000400050006
If I sort it in byte
07 d0070000 0300 0400 0500 06
07 is OK
2000 decimal is 07D0 in hex
I sending 7 2000 3 4 5 6
Why is the variable bigger than 2Byte switch around ?
Here is some of my arduino code
typedef struct __attribute__ ((packed)) sigfox_message {
uint8_t mode;
int32_t kg;
uint16_t moduleTemperature;
uint16_t Temperature;
uint16_t bat;
uint8_t ekstra;
} SigfoxMessage;
SigfoxMessage msg;
And here I insert data
msg.mode = 7;
msg.kg = 2000;
msg.moduleTemperature = 3;
msg.Temperature = 4;
msg.bat = 5;
msg.ekstra = 6;
Here is my send code
// Start the module
SigFox.begin();
// Wait at least 30ms after first configuration (100ms before)
delay(100);
// Clears all pending interrupts
SigFox.status();
delay(1);
SigFox.beginPacket();
SigFox.write((uint8_t*)&msg, sizeof(msg));
int ret = SigFox.endPacket(); // if (ret == 0) = OK
Serial.println("Status: " + String(ret));
SigFox.end();
