Hello,
I programmed MKRFox1200 to go into deep sleep mode and set a GPIO pin HIGH (Pin 6) when it wakes up every 1 minute. But the GPIO pin is not turning to HIGH. I tried with delay() instead of LowPower.sleep() and it worked. So the problem exists only when the board is operating in deep sleep mode.
Does anyone have a clue if it's even possible to turn a GPIO pin to HIGH on waking up from deep sleep mode? and if so, how to do it?
Following is a simplified code that I’m using
#include <SigFox.h>
#include <ArduinoLowPower.h>
pinMode(6,OUTPUT); // <<<<
if (!SigFox.begin()) {
reboot();
SigFox.end();
LowPower.attachInterruptWakeup(RTC_ALARM_WAKEUP, dummy, CHANGE);
digitalWrite(6,HIGH); // <<<<
delay(5000); // <<<<
digitalWrite(6,LOW); // <<<<
SigFox.begin();
delay(100);
SigFox.beginPacket();
SigFox.print("something");
int ret = SigFox.endPacket();
SigFox.end();
//delay(0.25*60*1000);
LowPower.sleep(1 * 60 * 1000);
void reboot() {
NVIC_SystemReset();
while (1);
void dummy() {
volatile int ttt = 0;
Thanks in advance
