MKRGSM sms lenght / Serial read / Cut at 120 characters
I send a sms with a lenght of 128 characters to the MKR1400.
The max lenght of a sms is 156 characters.
When i use the example sketch for receiving sms:
while ((c = sms.read()) != -1) {
      Serial.print((char)c);
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
I get the following output:
Sms Text blablablbalbalbalbalbalbalbalbalablabalbalbalablabblbslbdslfbslfdblsdbflsdblbslblbalbalbablbalbalbalbalbalbalba
11:25:07.825 -> END OF MESSAGE
11:25:07.863 -> MESSAGE DELETED
And the in like a second sms
11:25:09.872 -> Message received from:
11:25:09.872 -> +41786025000
11:25:09.872 -> Sms Rest Text
11:25:09.872 -> END OF MESSAGE
11:25:09.910 -> MESSAGE DELETED
So the sms is divided in like to sms after 120 characters. But i want it in one piece stored in a string. I do it like this (which worksperfectly to the first 120 characters..;=(
       Config_SMS += char(c);
Any tgoughts? Thx
Any thoughts?
I found it out, excuse my disturbance, here the answer if someone with the same prob finds this topic:
Unlike my example i used special characters in my sms ( | ) . These characters uses more bytes so the lenght of the sms decreases. The function in the lib is correct.
ERGO : if you want to send a long sms don't use special characters! I'm too lazy now to search for the specs..
The max lenght of a sms measured in characters are meant in "normal" characters, with umlaute, special characters etc the "lenght" is shorter.
The lib is correct:
int GSM_SMS::read()
int bufferLength = _incomingBuffer.length();
if (_smsDataIndex < bufferLength && _smsDataIndex <= _smsDataEndIndex) {
return _incomingBuffer[_smsDataIndex++];
return -1;
yes if you send text in UTF8 or UNICODE you will have multiple bytes per glyph (symbol/character) and you'll overflow the storage capacity of 1 SMS
if you stick to pure ASCII then you should not see the issue
Or, you can graduate to Grade 1, and start using multi-part text messages !
