MKRMotorCarrier Library Not Avaialble
Hi Everyone
I'm using a MATLAB R2019a and I'm trying to setup my MKR boards, objects and libraries. I have downloaded all the packages required via MATLAB programme and the 'add-on' button to use the MKRMotorCarrier library, i've even downloaded the MKRMotorCarrier folder and placed it in documents/Arduino/Libraries, I've followed all the steps required but the library still isn't showing up on my listArduinoLibraries function. The MKRMotorCarrier isn't an option I can tick (the image is attached below). I have also reinstalled the MATLAB multiple times to fix the problem, but no change.
Please help me.
Thanks
Hello,
Please recheck if the ArduinoMotorCarrier folder is present in the IDE path i.e. C:\ProgramData\MATLAB\SupportPackages\R2020a\3P.instrset\arduinoide.instrset\portable\sketchbook\libraries.
I am having the came issue with no solution at the moment.
Also Sravya, I do not have a folder called ProgramData in my C drive. If I go into Program Files -> MATLAB there is no SupportPackages folder.
Edit: So ProgramData is a hidden folder. I followed the filepath you mentioned but arduinoide.instrset did not have a folder called 'portable'. I tried simply creating the remaining files you said and then pasting the MKRMotorCarrier folder inside the last one called 'libraries' but this also did not work. I am using MATLAB version R2019a if that helps.
Hello,
Retry uninstalling and reinstalling the 'Add-ons' Matlab Support Package for Arduino Hardware and Simulink Support Package for Arduino Hardware. Also, please type the 'ver' command in command window and provide us the output.
I just wanted to clarify that the the ArduinoMotorCarrier is the same as the MKRMotorCarrier, right? I do not have the former in the path that was described. I was using MATLAB 2020a and was having problems so I downloaded MATLAB 2019b to see if I can go around the issues I was having.
I also have this problem. Please help me.
I'm using MATLAB R2021a.
