I'm working with an MKR Vidor board, and trying to save data on the embedded SDRAM memory, got the example template and look at the input and outputs form the board, but I don't really understand some of the signals.
Edit:
You can also find some simple controllers with google or from opencores.org. Note sure was Altera/Intel SDRAM controller free which would give you access to platform designer tool and it have avalon interface. You can also use platform designer to contvert it to AXI4 (Lite)
Bit I'm still looking for the name and function of the signals that I found on the MKRVIDOR4000_top.v file, in order to use it to code or test a SDRAM driver, I've been looking on intel files like:
But I couldn't find anything about those signals (or any SDRAM signals at all)
BR
Edit: Also, I would like to know if I need to use all of those signals in order to make use of the embedded SDRAM
The SDRAM signals are related to the AS4C4M16SA-7BCN chip. So you can't find them in the Cyclone10 datasheets. You must read the datasheet of the SDRAM chip.
The SDRAM behaves like a finite state machine, so the meaning of the pins changes with the variation of the internal state and the state of the other pins.
This table, present in the datasheet, shows the meaning of the various pins. You must read the details of the individual commands to understand how to use them:
The controller for the SDRAM, which will be implemented in the FPGA, will also be a finite state machine synchronized with the one inside the chip.
Edit:
Buttom of "simple SDRAM controller" has link to code "The complete demo code is available here." where "here" word contains link zip file that contains SDRAM_ctrl.v.
You can add them to a new quartus project and things should compile fine. If you run into issues let me know. Alternatively, you can install and use hdlmake for easier setup of the project as follows:
git clone https://github.com/hdl-util/sdram_controller
cd sdram_controller/syn/mkrvidor4000_quartus
# Get dependencies from GitHub automatically
hdlmake fetch
# Creates a Makefile
hdlmake
# Create Quartus project using Makefile
make project
# Open Quartus Project
quartus as4c4m16sa-demo.qpf
# now compile and blast the sof file to the Vidor 4000
The screen will look like this in case of success:
Which means the entire DRAM was written with a 16-bit counter equal to the 16 LSBs of each address, and then the value read from each address was correct.
purisame:
The SDRAM controller used by the official repos, altera_avalon_new_sdram_controller, is not available to Quartus Lite users.
What do you mean "not available"?
The _lite version of project builds just fine, and the only difference is using Nios /e instead of /f, and missing 16550_uart, both requiring license.
But I din't hear about sdram controller requiring license, nor do I have it.
It wasn't in the IP catalog for Quartus Lite and I couldn't find much about it online other than that it is part of Intel's Avalon interface. I can't find much for Avalon in the IP catalog either other than simulation stuff, JTAG, and SPI.
VStrakh:
This post from 2017 on the Intel forum suggested that it would not be available to Quartus lite users, which is why I thought it must not be available anymore.
So maybe it still works because it's needed for NIOS, though it's not listed in the catalog?
But the controller is here, available for free in Quartus Prime Lite 18.1, as required by VidorBitstream repository's readme.
It's not in the list of IP Catalog that opens from the quartus main window, it's in the IP catalog of qsys editor/platform designer, under "SDRAM -> SDRAM Controller Intel FPGA IP"
