MKRWAN 1300 not receiving uart
Hello,
I’m using a honeywell HPM sensor, and you have to send it commands via uart
Datasheet
I send the correct codes to the sensor, but I’m not receiving anything.
Connections:
sensor/mkrwan 1300
gnd/gnd
RX/TX(pin 14)
TX/RX (pin 13)
the sensor is connected to an external 5V power source
If I look, I see the arduino sending the values, but not receiving. I even tried running the arduino without connection to the pc (external power source)
Any ideas/ suggestions?
bool my_status;
// IMPORTANT!!! When working on an Arduino DUE,
// int is 32 bit (-2,147,483,648 to 2,147,483,647)
// For Arduino Uno int size is 8 bit, that is -32,768 to 32,767
// Use long or float if working with an Uno or simmilar 8-bit board
long PM25;
long PM10;
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  //while (!Serial);
  //Serial.println("Start!");
  //Serial.begin(9600);
  //Just discard everything the sensor will send at the beginning
  digitalWrite(LED_BUILTIN, HIGH);
  flush_Serial();
  // Stop autosend
  //Serial.println("Stopping autosend...");
  my_status = stop_autosend();
  // Serial print is used just for debugging
  // But one can design a more complex code if desired
 // Serial.print("Stop autosend status is ");
  //Serial.println(my_status, BIN);
  //Serial.println(" ");
  // Start fan
  //Serial.println("Starting measurements...");
  my_status = start_measurement();
  //Serial.print("Start measurement status is ");
  delay(5000);
  // Read the particle data every minute
  my_status = read_measurement();
  //Serial.print("Read measurement status is ");
  //Serial.print("PM2.5 value is ");
  //Serial.println(PM25, DEC);
  //Serial.print("PM10 value is ");
  //Serial.println(PM10, DEC);
  // Wait some time
  delay(10000);
bool start_measurement(void)
  // First, we send the command
  byte start_measurement[] = { 0x68, 0x01, 0x01, 0x96 };
  Serial.write(start_measurement, sizeof(start_measurement));
  //Then we wait for the response
  while (Serial.available() < 1);
  uint8_t read1 = Serial.read();
  uint8_t read2 = Serial.read();
  // Test the response
  if ((read1 == 0xA5) && (read2 == 0xA5)) {
    // ACK
    return 1;
  else if ((read1 == 0x96) && (read2 == 0x96))
    // NACK
    return 0;
  else return 0;
bool stop_measurement(void)
  byte stop_measurement[] = { 0x68, 0x01, 0x02, 0x95 };
  Serial.write(stop_measurement, sizeof(stop_measurement));
    // ACK
    return 1;
    // NACK
    return 0;
  else return 0;
bool read_measurement(void)
  // Send the command 0x68 0x01 0x04 0x93
  byte read_particle[] = { 0x68, 0x01, 0x04, 0x93 };
  Serial.write(read_particle, sizeof(read_particle));
  // A measurement can return 0X9696 for NACK
  // Or can return eight bytes if successful
  // We wait for the first two bytes
  byte HEAD = Serial.read();
  byte LEN = Serial.read();
  if ((HEAD == 0x96) && (LEN == 0x96)) {
    // NACK
    Serial.println("NACK");
    return 0;
  else if ((HEAD == 0x40) && (LEN == 0x05))
    // The measuremet is valid, read the rest of the data
    // wait for the next byte
    byte COMD = Serial.read();
    byte DF1 = Serial.read();
    byte DF2 = Serial.read();
    byte DF3 = Serial.read();
    byte DF4 = Serial.read();
    byte CS = Serial.read();
    // Now we shall verify the checksum
    if (((0x10000 - HEAD - LEN - COMD - DF1 - DF2 - DF3 - DF4) % 0XFF) != CS) {
      Serial.println("Checksum fail");
      return 0;
      // Checksum OK, we compute PM2.5 and PM10 values
      PM25 = DF1 * 256 + DF2;
      PM10 = DF3 * 256 + DF4;
      return 1;
bool stop_autosend(void)
  // Stop auto send
  byte stop_autosend[] = { 0x68, 0x01, 0x20, 0x77 };
  Serial.write(stop_autosend, sizeof(stop_autosend));
    // ACK
    return 1;
    // NACK
    return 0;
  else return 0;
bool start_autosend(void)
  // Start auto send
  byte start_autosend[] = { 0x68, 0x01, 0x40, 0x57 };
  Serial.write(start_autosend, sizeof(start_autosend));
  while (Serial.available() < 2);
    // ACK
    return 1;
    // NACK
    return 0;
  else return 0;
void flush_Serial(void) {
  uint8_t inchar;
  uint8_t count = 0;
  bool is_timeout = 0;
  // We set a 10 second timeout;
  unsigned long timeout = millis() + 10000;
  //Serial.println("Waiting for the first autosend.");
  while (Serial.available() < 1) {
    if (millis() > timeout) {
      //Serial.println("Timeout");
  // Do we have data in the serial buffer?
  // If so, flush it
  if (Serial.available() > 0) {
    //Serial.println("Flushing buffer...");
    // A data frame is 32 bytes
    while (count < 32) {
      inchar = Serial.read();
      count++;
      delay(10);
      //Serial.print(inchar, HEX);
    //Serial.println("");
Pins 13 and 14 are mapped to Serial1, not Serial (that is USB).
So you are sending codes to USB and not to the sensor.
MITEL:
Thank you very much, it works now.
