I am trying to use the deepSleep function to put the Arduino MKR 1310 into sleep mode for 2 seconds. It goes to sleep but doesn't wake up. What could be the probable reason? Thank you.
I suspect that wen you deep sleep the serial interface is disabled and not re-enabled afterwards so you can’t see it waking up.
Ou could either do something usb.attach(); before the “woke up“ line, but what would be much easier is that you turn the built in led on and off. I have a little routine that flashes the LED that i call to know the various states.
void blink_led(int ontime=100, int offtime=50, int flashes=1) {
//todo mattb1969 this function needs to take into account the state of the led on entry, if it is already high, make it low first.
while (flashes >0) {
digitalWrite(LED_BUILTIN, HIGH);
delayMicroseconds(ontime*1000);
digitalWrite(LED_BUILTIN, LOW);
if (flashes > 1) delayMicroseconds(offtime*1000); // If it is not the last flash, wait until returning to the top of the loop
flashes --;
return;
